CEL with P0031 code
Old 08-24-2008 | 08:16 PM
ucb2008's Avatar
Default CEL with P0031 code
I'm just installed the DME header, did the anti-fouler trick to the o2 sensor on s-pipe then got the CEL with P0031 code. So I've replaced the primary o2 sensor on the header but CEL still there with same code
Any suggestion?
btw my car isn't under factory warranty
Old 08-24-2008 | 08:22 PM
nlataille18's Avatar
P0031....HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
IDK what it means but thats what your code reads.
has something to do with the frist 02 sensor
Old 08-24-2008 | 08:24 PM
ucb2008's Avatar
i replaced it with new Bosch o2 sensor but the CEL still there .
Old 08-24-2008 | 08:26 PM
Scott8's Avatar
did you clear the code?
Old 08-24-2008 | 08:27 PM
ucb2008's Avatar
i did 3 times already
Old 08-24-2008 | 08:31 PM
CSOCSO's Avatar
try to replace the o2 sensor on the s pipe... and how did you do the fouler trick on the s pipe?
did you tried to put 3??? i have 3 on my s pipe because the CEL came back with 2 fouler
Scott8's Avatar
what kind of CEL fix do you have?
Also, what grade gas do you use? Since I was running 93 from my turbo when I installed my header again the ECU was use to the 93 with the header. when I went back to regular gas it made the CEL go back on until I put 93 back in. weird as crap but took the header back off, ran it with regular gas again, then reinstalled the header and cel and hasn't come back on since!
Old 08-24-2008 | 08:34 PM
ucb2008's Avatar
i use the anti fouler trick on the s-pipe with 2 spark plug (1 drilled 1/2" & 1 not)
Always use highest gas grade since I bought it
But the CEL code is P0031, is it related to o2 sensor oon s-pipe ? Hmmm
Old 08-24-2008 | 08:36 PM
CSOCSO's Avatar
^^^P0031....HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
i have no clue what is that means..
Old 08-24-2008 | 08:37 PM
Scott8's Avatar
unless you are running F/I I would save the extra cost on the premium gas and use the regular since that is what the car calls for
you have the anti foulers in the right order? You may also want to try the MMW CEL fix since that is a full pipe with a right angle
Old 08-24-2008 | 08:41 PM
ucb2008's Avatar
I'm going to buy 2 more spark plug to install. Let see what happens
Old 08-24-2008 | 10:11 PM
ucb2008's Avatar
god .... 4 spark plugs ... clear code .... but still CEL with same code
Old 08-24-2008 | 10:52 PM
B_Real45's Avatar
Did you clear the code and then reset the ECU after installing the new O2 sensor?
The code may come back if it's not cleared and the ECU reset.
Old 08-24-2008 | 11:05 PM
ucb2008's Avatar
do i need to do both ECU reset and clear code form my scanner?
Old 08-24-2008 | 11:08 PM
Scott8's Avatar
scanner usually does the trick. couldn't hurt pulling the battery lines and doing a full reset
Old 08-24-2008 | 11:12 PM
ucb2008's Avatar
if scanner can do the trick, it means the CEL still stick with me ...
Old 08-24-2008 | 11:19 PM
blacktrdtc's Avatar
HaYu Racing
what kind of bosch p2 sensor did you replace the stock one with? did you make sure to get the wideband? i think it has something to do with the primary o2 sensor.
Old 08-24-2008 | 11:20 PM
Scott8's Avatar
going to ask this since no one has... is it plugged in correctly?
Old 08-24-2008 | 11:21 PM
ucb2008's Avatar
sure it is in the hole it supposed to be
Old 08-24-2008 | 11:22 PM
Scott8's Avatar
sounds like another thread we are both on....
bank 1 is the primary on the header
short band replacement of a wide band would still throw a CEL.
