CEL P0420 - Replaced Cat, CEL came back on..What Next?!
Good Morning Gents,
I have been battling this issue for over a month now, I have replaced the MAF sensor and the Catalytic Converter/header this weekend to clear error codes to test for emissions this month. I have 05 tC with 140k miles. As i worked on replacing the Cat, I pulled the negative off the battery to clear the code. I took the car for a test run after install, and within 15 miles the CEL popped back on, and when driving around, at about 75 miles it turned off. I woke up this morning and went to work, and the CEL came back on again. Went to AutoZone and the P0420 is active. Looking through all the forums regarding this issue, it seems like an O2 sensor could be bad, which one should I replace first?
Thanks in advance
___
Thanks in advance
___
Primary O2 sensor on header probably, $200+ from the dealership.
I have an extra one used, let me know if your interested.
___
___
Like mention above. Primary O2 Sensor on the manifold.
Replacing MAF Sensor and Cat wouldn't solve that code. It's a sensor related issue.
__________________
__________________
1st- P0420 is for catalyst below threshold (meaning catalytic converter is not up to par). Primary sensor wont do jack, if anyrhing your secondary sensor could be bad not giving the computer correct readings.
2nd- Where did the replacement come from? If it says made in China it's junk, even a new catalytic converter will show as bad, there parts don't meet our requirements. Make sure it says OBDII compliant.
Sent from my SGH-T999 using Tapatalk 2
__________________
__________________
Interested in this outcome as well. I have the same code and it's ____ing my off. My OEM cat only has 6k miles on it and there are no apparent signs of damages to the cat or entire manifold. Really don't want to replace the $400 manifold.
1st P0420 is for catalyst below threshold (meaning catalytic converter is not up to par). Primary sensor wont do jack, if anyrhing your secondary sensor could be bad not giving the computer correct readings. 2nd where did the replacement
come from? If it says made in china its junk, even a new catalynic converter will show as bad, there parts don't meet our requirements. Make sure it says OBDIi compliant.
I just had the same issue with mine and I had just put in Dezods Catted Header 3 month ago so I bought a new O2 and now 300 miles later light still off.
The P0420 code is for both sensors and the cat it's just finding which one is causing the CEL.
___
___
Well I replaced the one be4 the cat and CEL light hasn't come back and I had the P0420 Code.
Code was coming on every 50 miles. I just kept resetting it thinking it would go away lol. So i gave up and I replaced the first sensor be4 the Cat and reset the Code. now I'm almost at 400 miles and no CEL (knock on wood lol)
Sent from my SGH-T999 using Xparent Skyblue Tapatalk 2
____
____
articis
25
04-21-2007 01:49 AM
TCTuNeR80
10
05-08-2006 10:42 PM
