Changing Clutch Fluid
RESEARCH.
The clutch and brake fluid are the same as you stated, no need to call it clutch fluid. They run off the master cylinder and slave cylinder of the car. The only time it needs to be changed is IF the fluid appears dark and murky in color.
Yes the hydraulic fluid reservoir is shared but due to the hygroscopic nature of brake fluid (has a tendency to absorb moisture) it is recommended to change it once every year or two for to maintain optimal brake performance. YMMV.
pinkie1205
03-30-2015 03:31 AM
mrsocks
01-20-2015 01:29 PM
