clutch master cylinder
Hey man I just replaced mine and the two pieces of advice I can give you is remove your brake fluid res but dont unhook it and remove your seat. It is a PITA though. The hard brake line sucks to put back on! Good Luck.
Well I replaced mine because my clutch pedal had started sticking to the floor when I depressed it. I bled the line and that wasn't the problem and I could feel a catch in the clutch pedal on the way back up, so that was my only conclusion. It fixed it for me.
![Exclamation](https://www.scionlife.com/forums/images/icons/icon4.gif)
The clutch master cylinder in my 2006 scion tc is shot and every replacement cylinder is missing an intake port and an output port....my question is WTF?!? How do you eliminate 2 ports that Are obviously needed?? If someone can help me I'd greatly appreciate it... I you could email me @ njanarchy@yahoo.com thatd be cool.. Thanks
i have a stage 2 clutch in my 07 tc, and recently it has been sticking to the floor when i shift. theres times when it will come back out after shifting and other when i have to pull it out manually. took it to get it checked and was told need a clutch. could it be the cylinder?
steeze69
05-24-2021 02:57 AM
