Code P0016 and What is a VVT Sensor?
Old 01-10-2020 | 08:20 AM
scottfetsh's Avatar
Default Code P0016 and What is a VVT Sensor?
OK, that was about P0017, not P0016 very similar I guess. OK, what is a VVT Sensor?
I know the Cam Sensor. And why not a Code for that?
In my past correlation errors are when the timing chain is off by a tooth.
____
Old 01-10-2020 | 07:17 PM
MR_LUV's Avatar
Administrator
Administrator
Old 01-10-2020 | 11:11 PM
62Fender's Avatar
Did you check the actuator gear on the front of the camshaft? Here's a Toyota technical service bulletin that might help.
https://www.autocodes.com/uploads/toyota/EG005-07.pdf
Old 01-11-2020 | 10:24 PM
scottfetsh's Avatar
62 fender just replied and sent me a pdf that answers the problem the VVT Actuator on the cam gear must be in a unlocked position BEFORE you can set the timing chain.
This is not shown in the FSM and why when you rebuild the engine or change the head gasket this problem occurs.
_____
File Type: pdf
Old 01-12-2020 | 03:10 AM
MR_LUV's Avatar
Administrator
Administrator
scottfetsh,
Thank you and 62 fender for Sharing the Followup. A lot of people don't bother to Followup.
__________________
Julio3216
02-06-2017 01:02 PM
truetide
01-25-2012 11:23 PM
HondaKiller
08-17-2009 06:51 PM
Rydrdg
02-01-2009 12:36 AM
weeloTC
06-25-2008 01:54 AM
Quick Reply: Code P0016 and What is a VVT Sensor?
