Do we really need that Second Cat?
OK, my question is do we by law really need the Cat that's on our midpipe cuz us tCs have
a Cat on the Headers and I'm pretty sure that the Header Cat will reduce emissions
____
____
Depends on where you live... in CA, you probably need it for emissions testing (I don't know for sure, just guessing since CA is a PITA for testing). Anywhere else, it would depend on what kind of inspection they're doing.
But technically, it's there for a reason - if our car really didn't need it, it wouldn't be there. I don't think you could rely on just the header one to reduce your emissions sufficiently - that's why there are two.
Then again, if someone wants to remove it, they're probably going to remove it whether it's 'legal' or not.
yes but i keep thinking its only there because its designed to be a LOW emissions car not a just passing emissions car...cuz those like 1989 camrys we all see driving around with black smog coming out pass emissions and they have 1 cat..
well no that i think about it why should i care im gonna get a catback and only have the header cat....non on the midpipe wanna kno why, well new cars dont get tested with the sniffer they use the OBD scanner and well catbacks dont throw a CEl
Ya, there's no sensor AFTER the 2nd cat, so removing it doesn't really do anything to your engine directly except change the flow/pressure of your exhaust - which may or may not have any long term effects. Don't think so though. I think if I did anything in that area, I'd just replace it with a highflow one.
Removing the second cat will add minimal (if any at all) power. Likely nothing ever noticeable except in your head. Most of the constriction for the tC's exhaust is well before that section of pipe in the first cat/header and the spipe. That is... unless you have already replaced the header/spipe to free the flow of the exhaust even further to the second cat, you won't get much of anything out of it.
well the one thing i noticed about replacing the mid-pipe is the weight the stock mid-pipe...man that thing is heavy as hell!!! i live in cali so i'm pretty sure the 2nd cat is needed for emissions so i screwed up for selling my oem mid pipe...hopefully i won't get caught and when it does come for testing (5 years from now..i have an 09) then i'll just pay extra to have them pass me..yup some smog places will pass you if you pay a little extra depending on who you know
If you have a friendly neigborhood shop that is willing to sell you a section of exhaust pipe can you just cut it out and get some of the lap joint clamps from Summit Racing? I cut out my Cat on my Ram and bought a 7 foot section of 3" tubing flared at one end to slip fit onto my 8-4-2-1 collector. I saved the section with the Cat on it and have a SS band clamp to restore my exhaust. Cat delete plus hypertech programming plus Jacobs ignition turned my 5.9 into a Hemi eater.
P.S. the truck is LAF, (loud as f---).
The car wont throw a code the 2nd o2 sensor is before the second cat. the second cat is there to make the tc a Ulev (ultra low emissions) vehicle. you wont fail emissions without the cat it will just make your car louder.
ST3ALTH212
16
07-04-2009 01:31 AM
