Drivetrain conversion kit ??
I heard a rumor that there is a conversion kit that can change the Tc from a FWD to a RWD. is this true??
they made a tc drifter and it was rear wheel drive ( not a lexus is)
https://www.scionlife.com/forums/viewtopic.php?t=218567
it isn't exactly un-possible. i mean, the ford focus has a 5.0 v8, rwd conversion kit...sure it only costs 20 grand on top of the car itself, but yeah, it can be done.
That Focus is Bada$$. I wouldnt mind owning it for sure. But back to the point, I dont really see how it could be done without custom fabbing all the parts. To my knowledge, and I could be wrong, there arent too many pieces that transfer over, and I know that there isnt a tc in Japan, maybe Europe but I dont think so.
To make it RWD is gonna take a shop and at least $20,000 to get started......for that money get a Z
No sir...
The Toyota Avensis shares the same chassis as the tC, however, the Avensis is AWD. THE RS*R team that built the Formula D tC essentially removed the front portion.
It wouldn't be easy or cheap, but 20k is a bit high. I interviewed Ken Gushi awhile back, and intended to release it as a podcast, but I've been busy. When I get around to posting it, I'll let you guys know.
2 things come to mind when thinking about a RWD tc.......
the rear end is the easy part, since we already have a "driveshaft tunnel" and the AWD caldina rear end (maybe even the new matrix AWD) will bolt up, if not mounts could be made pretty easily!
biggest problem is, finding a transmission to work with out transversely mounted engines, wich would mean either custom making one, or simply modifiying an AWD tranny to work rear-wheel drive (point in case, one does not exist)
only other option is to longitudinally mount an engine (just like the RSR tc) which requires the use of a different engine(which lots of people say it wouldnt make the Tc a Tc anymore, like they say about the RSR) custom mounts etc etc etc etc etc!!!
so yes, lots of bling bling is necessary
jchuma
02-11-2015 12:55 AM
