EBAY mangaflow TRUBENDS highflow cat back picts/vids
Old 08-19-2008, 12:20 AM
magyver's Avatar
yeah, that bend under the rear cross member could be better.. but i used a pipe clamp and a spring stabilizer rubber chunk and wedged it inbetween.. all is good..
i love it when i put on the axelback only.. i just wanted it a tad bit louder..
magyver is offline
Old 08-19-2008, 03:34 PM
D_Phlat's Avatar
yep could be louder, but nice purr. Got a photo of the magyver pipe rubber stabilizer?
D_Phlat is offline
Old 08-19-2008, 10:08 PM
magyver's Avatar
will take one in a bit
magyver is offline
Old 08-20-2008, 03:49 AM
HANSome's Avatar
this exhaust is sexyyy as hell! I just put it on and omg what a difference.
magyver does your exhaust tip stick out far b/c my exhaust tip seem to be out far and it annoys the hell out of me....I will take pics later
HANSome is offline
Old 08-20-2008, 03:51 AM
trentonm's Avatar
ya i noticed that... one thing that I am thinking about is getting their piping, cut the tip and reweld on a new tip to push it back some. or even attempt to bend the hangers a bit to get it to sit farther back.
trentonm is offline
Old 08-20-2008, 04:53 AM
magyver's Avatar
mine dosent stick out that far.. its not recessed, but i think its perfect.. i also have a lip though..
i believe those rubber things are called coil stabilizers.. but not 100% sure.. i needed em on my s-10 that i had a 5/4 drop in.. but they have come in useful i'll tell ya what.. i just cut em in half.. they are pretty beefy.. got over 4K on it and it hasnet moved or melted away.. ends the rattle instantly..
magyver is offline
Old 08-20-2008, 07:24 PM
D_Phlat's Avatar
thnx for pics magyver. Interesting mine appears to go around the other side of the tow hook than yours! I fixed my rattle with a clamp. I will prolly go back in and add some insulation since I don't wanna transfer too much heat from pipe to tow hook.
D_Phlat is offline
Old 08-21-2008, 12:23 AM
HANSome's Avatar
does it rattle after u shut off the car? cuz mine does.
HANSome is offline
Old 08-21-2008, 12:27 PM
magyver's Avatar
not mine
magyver is offline
Old 08-21-2008, 01:53 PM
D_Phlat's Avatar
So i got dirty again last night and went back under :-) To recap I have a borla axle back- I think magyver said his is the magnaflow catback, so that could account for some differences. I was wrong when I said mine went around the hook on the other side- but my bend seems to be further back (rear of the the undercarriage) so I used a strip of exhaust insulation and wrapped it around using a pipe clamp and put it on the longitudinal part of pipe (running from joint to bend)- wedged it between tow hook and exhaust - viola! problem fixed. My previous solution (inferior to magyver's) took care of the rattle but created a creeking noise, and I was concerned that the exhaust didn't really "hang" when pipe clamped to tow hook. This could prolly cause stress on the joints. Thanks for the pics and ideas magyver. BTW I made trubendz aware fo the comments and they are looking into it. HANSome- look for pics I'll take over weekend and post.
D_Phlat is offline
Old 08-21-2008, 03:54 PM
HANSome's Avatar
well heres are the pics from the exhaust...as you can see that the tip is wayy too out. I may have to cut the tip and and weld it back on...and also do you guys think I should weld the exhaust together because I only have the clamps on.
HANSome is offline
Old 08-21-2008, 09:02 PM
magyver's Avatar
i didnt weld mine, nor did i use the clamps.. i couldnt get the clamps tight enough to stop the pipes from spinning inside.. but they were fairly tight pipes.. so i just took a 1/4" self tapping screw sand put one screw in each side fo the muffler.. not spinning now and no leaks
magyver is offline
Old 08-22-2008, 12:47 AM
highvoltage1's Avatar
Well from reading this quality fitment does not seem to be there forti.
highvoltage1 is offline
Old 08-22-2008, 01:57 AM
magyver's Avatar
well, i'll take a little elbow grease vs paying an a$$load more for a brand name kit that sounds the same.. im not affriad of a little challange..
magyver is offline
Old 08-22-2008, 03:07 AM
How much was your kit?
Old 08-22-2008, 12:24 PM
magyver's Avatar
$310 magnaflow High flow cat with magnaflow muffler.. non ricer looking style setup...
magyver is offline
Old 08-22-2008, 06:40 PM
D_Phlat's Avatar
$205 plus shipping for borla muffler and axle back pipes.
D_Phlat is offline
Old 08-22-2008, 06:43 PM
D_Phlat's Avatar
magyver- I'm no exhaust expert (obviously) but not using clamps or welds on the joints sounds like a very bad idea to me. You can't necessarily see a leak, but exhaust is toxic, and the job of the system is to get that gas out the back at the farthest point possible. I would go back and slap them clamps on for insurance.
D_Phlat is offline
Old 08-22-2008, 10:02 PM
magyver's Avatar
the clamps broke before the pipes stopped spinning.. its all good.. i've been building/piecing exhaust since for the last 12 years.. its all good.. my s-10 stops right under the cab.. its all good.. but thanks for your thoughtfullness..
magyver is offline
Old 08-23-2008, 12:38 PM
HANSome's Avatar
I finally shorten my exhaust now. I will take pics shortly.
HANSome is offline
Quick Reply: EBAY mangaflow TRUBENDS highflow cat back picts/vids
