End to oil consumption forever.
Old 02-05-2023, 02:50 AM
Sciondoctor's Avatar
Ll
Sciondoctor is offline
Old 02-12-2023, 02:20 PM
Super Moderator
SuperMod
MileHightC's Avatar
Here's what I think, taking off my moderator cap for a moment...you, in all likelihood, haven't stumbled on any kind of miracle fix that someone else out there hasn't already tried. 'Flushing' the engine with whatever miracle solvent one decides to use is a temporary solution at best and a quick way to further damage an engine at worst. if this solvent is stripping the anti-friction coating off the skirts of the pistons I'd question what it might be doing to seals, gaskets, bearing coatings, etc.
Even if it does work initially, it's not going to fix the design issue that caused the problem in the first place and you'll be back looking for a fix again in relatively short order. I'm sure if Toyota could remedy the issue with a simple 'engine flush' with the 'miracle solvent du jour' they would have gone that route as opposed to re-designing pistons and ring packs to fix the issue and then rebuilding motors under warranty.
If someone thinks you've stumbled onto the Holy Grail of oil consumption issues and they want to send you $200 for you sage advice then so be it...it's their money. The fact that you've been moderately secretive about this whole thing and are trying to pedal your magical instructions, which goes against the crux of public forums where the thought is to share advice, leads me to believe that you've done ZERO long term testing and don't really have any answers other than, "Look how clean this stuff looks..."
Show me some long-term testing and the results of your flush after another 100,000 miles and perhaps I'll change my opinion.
MileHightC is offline
Old 02-21-2023, 05:49 PM
62Fender's Avatar
I'd be interested to see "cleaned" one-piece oil rings and or piston return ports that get clogged with hard carbon. It's one thing to clean oil sludge on non-combustion areas of the engine. Hard carbon is a different problem and no solvent I've read about will dissolve it. Like MileHightC said, even if there was a chemical that dissolved carbon, it wouldn't fix the low-tension rings nor the undersized, piston return ports. Given enough time, the oem oil rings will stick in the piston groove and rub a wear spot on your cylinder wall. That's where major consumption begins and no chemical will repair that damage.
62Fender is offline
Old 02-25-2023, 03:42 PM
Super Moderator
SuperMod
MileHightC's Avatar
If you CashApp me $199 I'll tell you how it's done...
Old 02-25-2023, 04:46 PM
62Fender's Avatar
lol
62Fender is offline
Old 02-26-2023, 03:05 PM
An
Old 02-26-2023, 08:33 PM
62Fender's Avatar
Originally Posted by Sciondoctor
Anyone who is ready to flush their motors to perfection...
should understand two things. Chemicals will not:
clean burnt carbon from combustion components.
repair mechanical wear due to design flaws.
62Fender is offline
cmv138
12-27-2009 04:55 AM
jam3stc
03-30-2009 02:05 AM
LostCause
06-07-2007 01:13 PM
cmlloveless
12-08-2006 01:17 AM
chicago_guy
04-19-2005 06:34 AM
Quick Reply: End to oil consumption forever.
