Eurathane mounts, make them now or wait:)
If you can let your car sit for a couple of days you can make your own filled mounts.
I use Devcon Flexane 80, a two part eurathane casting compound.
Just pull the front and rear mounts out, tape up one side really well, set them on a solid surface and well balanced, supported. Mix the eurathane and pour until filled to the edge of the mount. Let it sit and when done peal off the tape and intall them.
A 1 lb kit is plenty to do two cars front and rear mounts, costs around $30 per kit, a bit tough to find, I found a local dealer on the Devcon website then called them to order it, had it one day later
http://www.devcon.com/devconfamilypr...m?familyid=151
Rick
Rick
I have not done the tC just yet, we are finishing up our shop setup then will get busy dropping the tranny to install the LSD, 10lb flywheel, PP, 6 puc sprung clutch, fill the crossmember with structural expanding foam, fill the mounts, install the front sway bar and finish up by installing the Wilwood BBK they custom made for us
We will take alot of pics and when have time post the whole scenario.
I already know they will make a huge difference, done them on other cars before
Rick
Rick
MinusPrevious
15
12-12-2020 06:47 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
ToyTuners
11-04-2003 07:17 AM
