Exhaust Fumes
Exhaust Fumes
Hey all, ok so the past two week i installed header in my car and i been smelling a stronger exhaust fumes. i smell it every time i stop at a light. it started after i installed the header. my mods are injen cai>aftermarket header>tusdo mid pipe> tusdo axelback. i have no cats on the car. could this be why im smelling some exhaust fumes?.
THanks in advance
THanks in advance
what are you smelling exactly... free flow exhaust, means more fumes out. cat are built to absorb some chemicals and just let less harmful ones pass. so you should be fine... just make sure you are not smoking. white fume usually means water, black - gas and bluish oil...
also check for the leaks via sound, when u rev it up, if it sounds farty and raspy from the FRONT of the car, better get that plugged up! =) I had that issue. Rasp from the rear end, better put on some resonator (s)
carid
02-09-2015 01:49 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
