!!!!Fujita Cold Air Intake...Please read!!!!
Old 12-07-2009, 08:20 PM
  #121
chekmi21's Avatar
My car had the Fujita CAI when I bought it. When I bought and drove it for like 500 miles, no CEL. CEL came on, brought it back to the dealer, they swapped out for a new MAF, no CEL. Drove it 100 miles, CEL is back on. CEL goes off and then comes back on. Annoying. I'm just taking the CAI and need to get a stock intake to replace it with.
chekmi21 is offline
Old 12-08-2009, 02:12 AM
  #122
08txTC's Avatar
Mine and a friend of mine that has this intake does the same thing the check engine light comes one. Aside from drinking gas while it is on i was told that our MAF sensors do not like anything passing by them. Seeing as the filters are oil based that travels through the intake and getting stuck on the senor thus throwing a code. After a while it will go off. Mine comes on and off every blue moon or so many miles but then turns off after a few. So i was told to get a dry air flow filter non oil based and that should take care of the problem. Having done so yet as it really doesnt bother me that much. I have a old AEM filter that i need to clean once the time comes to change filters i will use that and see what it does.
08txTC is offline
Old 01-05-2010, 12:49 AM
  #123
goke186's Avatar
Thumbs up
OK, so I just wanted to let you all know that I got a-hold of Fugita and sent them a pic of my intake and apparently their early '07 tC intake diamiter at the MAF sensor is too large. I sent them a pic and they confirmed i had the early version and are sending me the new pipe for free, they have assured me that this new pipe will prevent my P0101 Code in the future.
I know someone else either in this thread or another has done the same thing.
I have attached one of the pictures that I sent to Fugita below.
I will post a picture of the new pipe next to the old pipe after it arives so you can see the difference.
Attached Thumbnails !!!!Fujita Cold Air Intake...Please read!!!!-100_0094.jpg
goke186 is offline
Old 01-07-2010, 09:32 PM
  #124
Team ScionTific
silvertcgirl09's Avatar
I have an intake as well and when it got installed the check engine light went on as well...i thought maybe the computer didnt recognize it....so when i went to get the oil changed they took it off. Doesnt it happen with all intakes installed?
silvertcgirl09 is offline
Old 01-08-2010, 12:03 AM
  #125
goke186's Avatar
Shouldn't but if you have it reset and it never comes back on then you wont have to worry about it, mine(and others) keeps coming back on and Fugita was and is aware of the problem and so they have adjusted their intakes accordingly. I got my new pipe today so I will post comparison pictures tonight.
goke186 is offline
Old 01-08-2010, 04:08 AM
  #126
goke186's Avatar
Thumbs up
I installed the intake piece tonight, here are some pics.(Old intake is the one at the top of the pic and the new one is below it) So far no CEL... but I'll keep you guys updated if that changes.
Attached Thumbnails !!!!Fujita Cold Air Intake...Please read!!!!-100_0098.jpg   !!!!Fujita Cold Air Intake...Please read!!!!-100_0095.jpg
goke186 is offline
Old 01-08-2010, 12:02 PM
  #127
GQQSE13's Avatar
when i installed mine i got the CEL at first like everyone else. you jut disconnect the bat for about 5 min to let things reset and then hook it back up
GQQSE13 is offline
Old 01-09-2010, 06:05 AM
  #128
goke186's Avatar
lol yeah i did that do... about 7 times a day for 3 days then just left the cel on till I got the new pipe
goke186 is offline
Old 01-10-2010, 01:41 AM
  #129
Philip-tc's Avatar
where you get the new pipe from? im having the same problems
Philip-tc is offline
Old 01-10-2010, 07:32 AM
  #130
goke186's Avatar
Contact Fugita via email, it took them approx. 4 to 5 days to get back to me maybe less. Got my pipe for free, just had to take a pic of the old pipe installed and promised to destroy (and then take pics of) the original pipe as soon as I installed and checked the new pipe.
(Make sure everything fits correctly before you destroy your original pipe!)
Customer service was pretty straight forward and easy, they were very nice and never just assumed I was some guy trying to get a free intake. I was quite pleased with the overall experience.
goke186 is offline
Old 01-10-2010, 04:26 PM
  #131
Philip-tc's Avatar
alright man thanks alot
Old 01-12-2010, 08:52 PM
  #132
KFedyszyn's Avatar
i had the same problem wit mine cai...could it be the intake itself and maybe sucking in too much air..and if it is do i need a new intake or will the comuter adjust to the new air flow and maybe the light will go off after a while?
KFedyszyn is offline
Old 01-12-2010, 08:57 PM
  #133
DJ08tC's Avatar
disconnect the battery for alittle bit. Then hook it back up, let the car run for 10 mins or so then take it for a slow easy drive so the ecu can learn, if it comes back then you have some kind of problem.
DJ08tC is offline
Old 01-13-2010, 01:58 AM
  #134
goke186's Avatar
Yeah the computer does compensate BUT the MAF sensor is getting confused because the pipe diamiter is too large so it is tripping the CEL, I installed the new pipe that fugita sent me and since then no CEL. Fugita just made the diamiter of the pipe at the MAF too large.
goke186 is offline
Old 02-06-2010, 12:59 AM
  #135
jaylouie's Avatar
The problem is not exactly the pipe diameter. The pipe diameter of the stock intake box maf sensor is 2.75" which is the same as the fujita pipe. The problem is that the MAF sensor is pointing the wrong way. The original intake box points the MAF sensor with the connecting wires pointing to the cabin. the Fujita intake makes the MAF sensor plug point away from the cabin, which is opposite directions. FUJITA screwed this one up big time. you can call them and get a warranty exchange.
jaylouie is offline
Old 02-06-2010, 04:45 AM
  #136
TJKASS's Avatar
weird, my original 2.75 faced the right way and i still got occasional CELs (in the wet). still switched it out for the new one tho. decided to go polished this time so now ive got a half half system lol.
TJKASS is offline
Old 02-07-2010, 07:33 PM
  #137
Nooomoto's Avatar
LOL...I'm having the same issues on my 07 with their intake. Just tried to email them and the mailbox is full! Damn it.
Nooomoto is offline
Old 02-07-2010, 08:57 PM
  #138
gjpjr84's Avatar
sounds more like it was installed wrong or you tried to put the wrong year intake on the wrong year tC.
if you tried to put an 05-06 intake on an 07+ tC the MAFS would be installed wrong and have gap issues.
and putting an 07+ intake on an 05-06 tC, in addition to being rotated wrong as well the MAFS probably wouldn't even fit.
you can even see in the pics above, the MAF is seated in the right direction.
gjpjr84 is offline
Old 02-09-2010, 04:30 AM
  #139
jaylouie's Avatar
actually gjpjr, you are right, mines might have been installed wrong, but i still got the new version with the smaller diameter around the maf sensor after a warranty exchange. I tried emailing F5 and no reply, but when you call them, they will help you out, i spoke to a guy named paul. hope this helps
jaylouie is offline
Old 02-09-2010, 11:02 AM
  #140
SilverCFtC's Avatar
You got an 05-06 intake in an 07 box. Happened to me with my latest Fujia purchase. (Off of Ebay)
Randode.com sells an adapter that will work and has a cool skull on it.
-Sean
SilverCFtC is offline
Quick Reply: !!!!Fujita Cold Air Intake...Please read!!!!
