has anyone done itb on a tc yet?
^^^ no no im wondering if anyone has done ITB-individual throttle body's. its an alternative to forced induction. sorry if i was a bit confusing i was asking if anyone has used ITBs on a tc and how much HP they got or could get by using them
because? you're not going to get the benefits of a supercharger / turbocharger, you're not compressing air in, granted you'll have increased intake velocity but you'll have more heat soak better throttle response. basically its a show mod, you shouldn't expect much more than stock
ben sorry to burst your bubble but its not a show mod at all.... its actually fully functional and you actually do see gains from ITBs... average gains are from 15-25 whp .... i wouldnt have tried it if it was going to make me slower....lol...
BTW im still trying in my head how to make it work.. the DBW is the only issue..
really seems like a needlessly compliated investment and it would only be worthwhile if you were doing a complete n/a build up on the tc engine with high compression tuning.
yes, it can be done, but what do you get in the end? how much power do you think you would make?
i don't think that right. sorry to disagree but a lot of kid get great gain on other car esp if you use deferent cams. also if you wanted to run a a turbo on ITB its possible, guys use special manifolds that go to each throttle body
how would you have a turbo or supercharger with ITB? you would have to have a common intake manifold going back to the intake side of the cylinders from the compressor.
from what i've just looked up, it is all about getting the maximum amount of power out of high compression n/a engines.
not with s/c but with turbos i think ppl are basing the post off what SOME turbo manifolds used on the inside which is a velocity stack shrouded by the rest of the manifold... similar to ITBs only the velocity stacks are out in the open and not covered.
