has anyone done itb on a tc yet?
Old 04-30-2008, 09:17 PM
TCpete's Avatar
TCpete is offline
Old 04-30-2008, 09:20 PM
joeya28's Avatar
that is sexy.
joeya28 is offline
Old 04-30-2008, 09:31 PM
nebster's Avatar
Originally Posted by TCpete
ben sorry to burst your bubble but its not a show mod at all.... its actually fully functional and you actually do see gains from ITBs... average gains are from 15-25 whp .... i wouldnt have tried it if it was going to make me slower....lol...
BTW im still trying in my head how to make it work.. the DBW is the only issue..
he was comparing to a s/c and turbo, its not gonna be s/c turbo status thats what i was trying to say. plus each engine reacts differently so its had to say if it would still net 15-25 whp on a tc without supporting mods
nebster is offline
Old 04-30-2008, 10:38 PM
BuddhasTC's Avatar
and Pete can't start this until he finishes his valve cover...
BuddhasTC is offline
Old 05-04-2008, 04:52 AM
Bozuzu's Avatar
no one's going to argue that ITB setups aren't cool. but thinking that rigging that up on the 2.4 is going to net you 15 hp is lunacy. it's a waste of time unless you're going all motor, and on a tc there's not much reason to do that. just buy a turbo kit.
the best tech articles you'll find on ITB are on the best ITB in history, the BMW S62 (light shines down from heaven )
if you get a completely built head, cams, pulleys, gears, springs, retainers, valves, and bottom end, pistons, rods, rings, crankshaft, bearings, clutch, and flywheel, then you get to do ITB and it has to work, and you have to post a DIY in the tech section.
Bozuzu is offline
Old 05-04-2008, 05:51 AM
joeya28's Avatar
im wasnt asking so i could do it. once again i was just seeing if anyone had done it yet. and their are a lot of kids that do n/a set ups on tc so its not really far fetched.
joeya28 is offline
Old 05-04-2008, 07:22 AM
toyota_scion_tc's Avatar
It can be done it would not be cheap. You would see hp gains I am not going to say how much but every ITB setup I have ever seen kills torque. Yes it may be possible to see 10-20hp but you will lose a lot of torque.
toyota_scion_tc is offline
Old 05-06-2008, 11:02 PM
manjambles's Avatar
im intrested in doing this
manjambles is offline
Old 05-07-2008, 12:51 AM
joeya28's Avatar
how about a write up hahahaha^^
joeya28 is offline
Old 05-07-2008, 03:26 PM
manjambles's Avatar
i emailed p tuning about possibly taking this on as a project
Old 05-07-2008, 03:33 PM
TCpete's Avatar
if they could figure out a way to work around the DBW i would be all over it.. thats were i hit a brick wall full or jelly i couldnt climb over..
TCpete is offline
Old 05-07-2008, 03:40 PM
draxcaliber's Avatar
hmmm...curious, because how much room is there to work with between the intake manifold and the fire wall...i mean...wouldn't the air supply between the engine and firewall be kinda turbulant and hot? wouldn't this work out better if the intake side of the engine was towards the front?
draxcaliber is offline
Old 05-07-2008, 03:58 PM
manjambles's Avatar
whats the dbw?
the only thing i could think of to fix the issue of placement is to have then at a angle _/ it would still be effective.
tcpete ive heard that youve done alot to ur motor, how much hp you gain from all that
Old 05-07-2008, 04:02 PM
dbw is drive by wire.
you know, traditional gas pedals have a throttle cable that is pulled and opens and closes the pedal, and a throttle positioning sensor reads the throttle position and responds accordingly.
but on a dbw system, the gas pedal is just connected to a sensor, and it reads the pedal position instead and opens the throttle for you so that it can better control the fuel and ignition timing since it is a more precise system.
so you would have to either change it from a dbw system to a throttle cable system, or program an electronic throttle opening system for all 4 throttle bodies.
Old 05-07-2008, 04:07 PM
TCpete's Avatar
theres enough room to make ample velocity stacks... or you can have them go in a curve.. theres room... ive thought of how to do it.. the problem is the DBW.. the velocity stacks are a small minor thing
TCpete is offline
Old 05-07-2008, 04:08 PM
manjambles's Avatar
oh... all these acranims (sp?) lol jk rofl haha
ok i see where that could be an issue, look at the pic at the top the one tcpete put up it looks to be a sensor/plug or whatnot there, where did that itb come from
Old 05-07-2008, 04:11 PM
manjambles's Avatar
or is that just a maf
Old 05-07-2008, 06:40 PM
xdejablu3x's Avatar
hmm ITBs sound interesting on our cars. my cousin has some on his S2K and its sick!
xdejablu3x is offline
Old 05-07-2008, 08:04 PM
Bozuzu's Avatar
the dbw will be both the hardest obstacle and the best end result for ITB. the biggest complaint of the dbw is the lag, which I personally think sucks, but with ITB the air is right there in all cylinders on demand. again, look at the S62 BMW for solutions. they use potentiometers with dc servo motors and a small servo gearbox to operate the butterfly valves, the only way to do it with a dbw. good luck with that!
http://www.usautoparts.net/bmw/engines/s62.htm
Bozuzu is offline
Old 05-07-2008, 08:20 PM
Bozuzu's Avatar
oh and someone mentioned the firewall. there's plenty of room, itbs will take up less room than the stock intake manifold, which has about 3 different parts because of emissions stuff on it (egr, etc). you can always just do a throttle cable swap with a stand alone ecu. I'm sure someone's done it to a celica, and 808speedshop did it to an ae86 corolla. the more I think about it, the more I say go for it:
Bozuzu is offline
Quick Reply: has anyone done itb on a tc yet?
