HELP...burning serious oil!
Old 01-21-2012, 07:59 AM
youngflyer's Avatar
Default HELP...burning serious oil!
Im having a pretty rough run with my 2nd tc. First, the wheel bearings went after one month, the clutch master cyl goes out the next month, had to replace the whole clutch 4 months in, i just had to replace all four tires and now onto the biggest issues.
My tc is burning a crap ton of oil and leaking too. lately ive been smelling burnt oil and gas, and i kept checking the oil level and sure enough, its leaking about 2 quarts in between oil changes. The car still runs fine, idles a tad rough but barely noticeable. I pulled the dipstick tube out and i didn't see smoke so no blow-by. Smoke does come out oil cap on the valve cover. Smoke will also pour out of the exhaust when i get on it a little. My friend said oil is leaking from the timing cover and i can see a bit of oil pooling on the supercharger underneath the shaft but not enough to cause the issues im having. It doesnt help that the bearings might be going out in the supercharger too. Does anyone have any idea what it could be?
youngflyer is offline
Old 01-21-2012, 12:47 PM
PeArLwHiTe07tC's Avatar
depends on exactly where its coming from. if oil is leaking from the timing cover, its not gonna cause any issues as far as smoke from the exhaust. unfortunately, out motors have a tendancy to burn oil. its a big problem with the 2azfe motor itself. i have no idea as to why this failure occurs, but we do a few motors a month due to oil consumption. the only way around it is to replace it. i hate to be the bearer of bad news for ya, but this may be ur case.
PeArLwHiTe07tC is offline
Old 01-21-2012, 02:12 PM
borderguy881's Avatar
ever thought maybe the s/c seals are shot..
borderguy881 is offline
Old 01-21-2012, 03:30 PM
youngflyer's Avatar
Martin it could be the sc seals since the supercharger has been making a crap ton of noise and there is oil pooling on it. Could that cause the smoke in the valve cover and smoke coming out of the exhaust?
Old 01-21-2012, 03:47 PM
it could if its getting pushed into the throttle body. it could be a combination of the motor burning oil and the charger.
Old 01-22-2012, 01:19 AM
there shouldnt be pooling of oil that means its def got a shot seal...
and you said you have smoke come out when you open the oil cap right? thats normal and actually stupid to do cuz i know every 2az ive done that with shoots oil out of there hahaa, a better check is to pull off the pcv hose on the side and check for smoke.
what he said, i would first run a compression test its quick and easy to do, then if all is well its likely your s/c
Old 01-22-2012, 07:03 AM
youngflyer's Avatar
anyone think the motor is salvageable?
Old 01-22-2012, 07:22 AM
like i said in my above post...
Old 01-22-2012, 04:01 PM
youngflyer's Avatar
martin, know anyone with a comp tester?
Old 01-22-2012, 10:34 PM
sebbyxtc's Avatar
autozone^^
sebbyxtc is offline
Old 01-22-2012, 10:37 PM
youngflyer's Avatar
^ lifesaver lol
Old 01-23-2012, 06:39 PM
blackg5's Avatar
Hell, my 2AZ is stock and I just had to add almost a full quart @ 1200 miles on the oil change... 200k miles, always taken care of only started using oil after I ran seafoam thru the crankcase..
any ideas how to slow down the comsumption?
blackg5 is offline
Old 01-23-2012, 06:46 PM
youngflyer's Avatar
New car? Lol
Old 01-23-2012, 08:47 PM
thendawg's Avatar
What weight oil are you running? If youre running some of the eco-crap (0w20, 5w20), go to a 5w30, odds are itll burn quite a bit less.
thendawg is offline
Old 01-23-2012, 09:08 PM
New car? Lol
lol zak
Old 01-25-2012, 02:25 PM
blackg5's Avatar
New car? Lol
in due time good sir..
its always had 5w-30.. should i run thicker? I'm really not all that worried about it, just curious..
blackg5 is offline
Old 02-06-2012, 06:25 PM
youngflyer's Avatar
Hey guys just as an update, i pulled the piping off the supercharger and as expected, they were drenched in oil. So on the bright side, the motor still seems fine but on the bad side, the supercharger has blown seals and maybe bearings to but i cant confirm that :/.... Any ideas which route i should take?
Old 02-08-2012, 06:21 PM
ThatGuyAtGeweke's Avatar
find a place that can repair the charger, Ditch the charger, or replace it. Really the only options =/
ThatGuyAtGeweke is offline
Old 02-08-2012, 08:12 PM
torqueTc's Avatar
I would get smoke when my cat went bad. Are you throwing any codes yet?
torqueTc is offline
Old 02-17-2012, 09:25 AM
DeAnzaJig's Avatar
any results on the compression?
DeAnzaJig is offline
Quick Reply: HELP...burning serious oil!
