Help...having problems with my clutch
Old 07-18-2011 | 06:25 AM
youngflyer's Avatar
so i was at my witts end today and gave up...went out to see a movie with the girlfriend and came home and wanted to tinker a little more. With her help, we bled the slave cyl 6-7 more times and i started up the car with no expectations. What do you know, none of my car guy friends could get it working but my girlfriends touch must have done something. Either way the clutch is now working again and after adjusting it, feels like an oem clutch again..... VERY HAPPY :D!
Old 07-18-2011 | 02:44 PM
TCpete's Avatar
it must have been something you where doing before. i dont know the bleeding process you did but there probably was alot of air in your lines left over from when you swapped out the slave and then the CMC. im guessing your car buddy might have done it another way and taken out the air.
congrats on getting it going. im now 100% sure it was CMC that was faulty and NOT your slave.
after a few days of driving it id maybe bleed it one more time just get all the air out because it will creep around a little check your fluid level for the cmc then you should be free of problems.
Old 07-18-2011 | 03:20 PM
youngflyer's Avatar
thats a really good idea pete....you are officially god in my book btw! i really like the way it feels now too, after adjusting it, the clutch feels like oem, sooo smooth!
Old 07-19-2011 | 04:17 AM
05rs1's Avatar
im having similar issues....ive bled it so many times, even bought a vacuum bleeder and it still doesnt work,.....i have pressure but not from top to bottom on the pedal, i can press it half way down before i feel pressure....so my clutch isnt disengaging all the way....im all out of ideas...
Old 07-19-2011 | 05:05 AM
youngflyer's Avatar
Did you upgrade the clutch?
Check your fluid level in the reservoir
When you bleed it, does a steady stream come out?
Old 07-19-2011 | 07:13 PM
05rs1's Avatar
If you are asking me....than yea I have a ACT 6 Puck unsprung and I did bleed it and the reservoir is full.....
Old 07-19-2011 | 10:09 PM
TCpete's Avatar
what you need to do is adjust the engagement point on your clutch ^^^^ you might also need the pushrod extension from speed source
http://www.speed-source.net/
extended clutch slave cylinder pushrod... this will help with raising your engagement point. (some adjustment will need to be made on the clutch pedal if you use this product to dial it in to your liking)
Old 07-19-2011 | 11:09 PM
thendawg's Avatar
I have a 6 puck ACT (although mine is the xtreme pressure plate) and I have adjusted it, bled it multiple times with a vac bleeder, and even have a lengthened pushrod I made and mine still engages close to the floor. At first you literally had to have it on the floor for it to disengage - now after everything Ive done its much better but still the engagement point is alot lower than OEM - everyone else Ive known thats had this clutch has said the same thing, so i guess youll have to get used to it, I have and its fine.
Old 07-20-2011 | 12:08 AM
05rs1's Avatar
I tried it....I used a push rod from a v8 and cut it down
Old 07-20-2011 | 05:50 AM
youngflyer's Avatar
so are you saying you tried it before or after making this post? are you still having issues....Tcpete you beat me too it, i was going to say, it sounded like you need to lengthen the pushrod. I have mine almost all the way out now and feels like an oem clutch again but but i only have a stage 2...
Old 07-20-2011 | 02:34 PM
05rs1's Avatar
Before I posted anything I had already tried it....someone had told me about so I tried....1 thing I did notice is that I'm missing a bushing for the pin that holds the clutch master to the pedal....Toyota is delivering it to me at my job today so I'm going to try that and see what happens....I think it will help because when I start to push the clutch down, the pedal moves but the threaded rod for the master doesn't start to go in yet.....so we will see
Old 07-21-2011 | 05:28 AM
05rs1's Avatar
SUCCESS!!!!!!! I FINALLY fix my clutch issue....its not perfect but it works...its an idea i had weeks ago that i thought wouldnt work....so today i finally tried it...i extended the clutch master's rod that is threaded and goes to the pedal....now it grabs kinda high but im not missing gears and the gears aren't grinding....also i have to reach under the pedal and use my foot to hit the switch that allows the car to turn on when the clutch pedal is pushed in....i kno that i can probably wire it so i dont need the clutch but it kinda adds a little security to the car....if for any reason someone got in the car and tried to start it would kno that the pedal doesnt reach the switch....i will post pics tomorrow of my invention lol.....
Old 02-23-2012 | 07:49 PM
gmc_113's Avatar
did you ever getthis resolved? i think im havingthe same issue
Old 02-23-2012 | 07:55 PM
youngflyer's Avatar
Yupp the aftermarket pressure plate was to much for the CMC to handle... Went back to a stock clutch and couldnt be happier!
Old 03-05-2012 | 02:58 AM
gmc_113's Avatar
ok i need to get my cmc in. it was such a pain in the ___ today to work on. the CMC is behind the strut tower so hard to get to. not to mention the bolts that hold it in. ____ i was getting soo annoyed
Old 05-20-2012 | 02:07 PM
troy2003's Avatar
i know this thread is old, but didnt want to make a new one. When i push my clutch in i hear a whining sound, and third gear is a little rough to engage, my transmission "went" i thought with an exedy clutch but i was told after purchasing a stage 4 comp clutch and having it installed that the issue was not the clutch my exedy was fine. I was told it was the throw out bearing, well now i am having transmission issues again and i am beginning to wonder if with all the slave and master cylinder issues i have seen if that could be my problem and not the throw out bearing......???????. are there any diy writeups that i am not seeing????
Old 05-25-2012 | 04:44 AM
weslxa's Avatar
Troy, I don't know nearly as much about slave and master cylinders as the other guys here do, but I did help my buddy change out his clutch a few years ago and we posted a diy on here on how to replace the clutch and flywheel. All I can say about the throw out bearing is that when we went to put his new one on (from a spec stage 2) it was extremely tight, so he used a dremel to grind out a little so it would move more freely along the shaft before we put it all back together. I've heard a lot of other people suggest just using the stock bearing because of the same issue. Hope that helps
Dmmcclair
08-13-2015 08:14 PM
08bakerXxtc
03-19-2015 10:51 AM
yhwhdesign
10
02-06-2015 06:00 AM
baker08tc
12-30-2014 01:02 AM
tC4me
02-05-2004 03:30 PM
