Help Installing HKS Exhaust
Originally Posted by roflitzjinno
dude its all about hand tools and LONG i mean LONG PIPES! use the pipe as and extension on the rachet.. and then PULL or PUSH or which ever way your going.. physics man. physics!
Torque = Force * Lever Arm length. If torque must increase and force can't increase, the arm length must increase! Leverage!
Or, you know, $50 under the table works too. Not the ideal way out, but much better than triple that.
put the wrench on and kick it.... you don't want to pull... i pulled.. and then it popped... and i slammed my head on the jack stand... major owwie... not like kick kick... but like knock it... so it start moving.. or get your dad to do it...
Originally Posted by BigPinoyTC
The bolts are probably on there good from some rust.
Go to your auto store and ask them for this spray (forgot whats its called but they should know) it will eat through rust and works 10x better than WD40.
air tools
Some pretty good amounts of Force. Its what I used to get those same bolts off. Works like a charm. I would have preffered to use airtools though, but the aircompressor was blocked in the corner of my garage out of reach that day.
Yeah those two bolts were extremely tight. I had some help from another member on this board and we installed my HKS exhaust within 30 minutes. Just use some muscle and you should be able to get it off.
JM Auto Racing
12-19-2014 06:36 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
TheRedBox
31
12-02-2003 04:53 PM
