Hmm problems accelerating
Im gonna take the car to the dealer tomorrow to have a problem checked out, I tried searching here to see if anyone has had similar problems, but didnt come up with much. I just noticed this a week ago more or less, but has gotten real bad the last or two. Basically when driving usually in third gear (sometimes second gear, havnt tried higher gears cause of damn miami traffic), when i go WOT the car will rev up normally till around 4k RPM where it will all of a sudden stop accelerating momentarily, then kick up again, and do that over and over again. It is very very annoying, I noticed this on my way from work yesterday when I was going on the highway and was about 3/4 throttle and it would not want to advance past 4k rpm, after around 15 seconds it started to advance A LITTLE, but it was doing that on/off crap. Anyone have any ideas? Or what should I expect?
Things that might help the diagnosis: Engine has fresh oil (mobil 1 synthetic) 1400 miles ago, the car has 14300 Miles on the Odo. No weird lights are on the dashboard. No CEL, car revs just fine in idle. Car has pretty clean intake (short ram), has a flowmaster muffler, and a short shifter, and a grounding kit. Doesnt seem electrical, kinda feels like the timing is pulled on purpose by the car till I let off the car to about 1/2 throttle and accelerate normal, only on heavy accelerating does this happen. :-/ Any ideas?
It sounds like when your car hits open loop, it gets a bit wacky...
I'm sure they'll take a look at your MAF sensor... It may be malfunctioning, as well as possible vacuum leaks... Just make sure the situation is consistently recreatable, as the techs may want to go for a ride with you to get a good handle on the problem.
I noticed you have a aftermarket intake installed. I had this same problem on a differnt car of mine.
It turned out it was the cap from my intake that goes on the very end of the filter, it seems that it slipped off, flew up the intake and was actually hitting my throttle body, but only at 3/4 or more throttle.
My mechanic couldn't belive it when he found it, he said it might have actually been flipping around causing the engine to become starved for air.
Dont know if that's your problem or not, but good luck!
Originally Posted by Kenshin
Yeah, I was gonna swap out the intake tonight before I took it to the dealer to avoid problems. Ill take a look inside the TB to see maybe something is up. The car acts real screwy, I might take a video so you can see.
It's a good start and it's cheap. More than likely you'll have to hook it up to the diganostic computer. I have heard of shops doing this for free sometimes, so you might wana call around and see if anybody will do it. If the computer isn't coming up with any trouble codes.
I would think it would have to be something mechanical.
Does this happen while the car is in park/neutral too? Or just while it's driving?
Well I solved my own problem when I popped open the hood. The intake filter on my short ram was banging against the chasis which literally cracked it in half. Thus there was basically no filter to my intake, which was making my maf go all screwy. I threw in my old stock intake and it fixed it right away. Now I just gotta get another intake hehe .
Man that sucks. What kind of intake was it?
At least it was quick and easy to fix ;).
RY_TC07
07-18-2017 05:18 PM
CapnChunk
04-13-2015 04:06 PM
