how many of you kept your old tranny oil
im just curious...how many of you that change your own gear oil over to another brand like redline or something kept your old gear oil or you safely recycled it......cause some keep there old oil just in case but how long is too long...i understand if you run into a problem with the tranny and they some how see its not the OEM oil i know thery wont fix it but other then that i dont see why not
the only reason i ask cause i heard some people kept there old oil just in case....but once it its the pan or what ever you put it in it can get stuff in it....so i guess the answer is no recycle it....never reuse the oil unless you absolute have too..
NEVER reuse old oil..you run the chance of causing even worse problems. You're gonna put all that nasty crap that was filtered out from it's original use back into the car and you could seriously mess some ish up that way.
y would u want to keep dirty as$ oil nevergivein?
So then why are you keeping it if it makes no sense to you? lol the only reason it would void your warranty is if it caused a problem in which case you probably ****** up and used the wrong oil
