hp increase intake/catback/s-pipe/pulley ?
If stock 5 speed tc puts down about 140hp, what kinda increase would you expect from ...
- injen cold air intake
- megan cat back exhaust
- invidia s-pipe
- NST 3 piece pulley system
id love to add 20 rwhp but not sure if that stuff would add up to that
that stuff adds up to about 1000$
- invidia s-pipe
scionlife has this awesome feature called a search button that will probably pull up about 1000+ threads on this topic. I'm sure at least one of those can answer your question.
Oh and by the way, the tc puts power through the front wheels.
Re: hp increase intake/catback/s-pipe/pulley ?
- invidia s-pipe
- invidia s-pipe
23-30 (give or take a few)
Originally Posted by milkman713
With those mods you might have a sweet sounding tc, but imho 23-30 is max unless you get a header. Which im pretty sure adds more hp than the exhaust or intake.
your page says you have intake, axle back exhaust, one pulley the crank, headers yes, but your s-pipe in a box meaning not on car right.
thats different than the 3 pulley set, cat back exhaust(+ midpipe) and s-pipe instaled, + intake
basically im trying to find out is it worth 20 hp ......
3 pulley set
megan full cat back ( midpipe)
invidia s-pipe
injen intake
The headers i was thinking about getting but i dont know if i wana get rid of the cat and have to deal with the whole defowler throwing codes stuff
3 pulley set
invidia s-pipe
injen intake
hmmm maybe megan headers added to those 4 for the 20 to 25 hp
will this from weapon r solve all code problems
http://weapon-r.com/english/index.ph...oducts_id=6219
the s pipe is on now, and the 3 pulley setup isn't worth that much of a difference, the crank pulley is the biggest one for results, you might gain .5 hp from the other two pulleys. and if you look at the parts im running, its all the best stuff, check out the dyno sheets on the parts round up thread, the alphawerks header is the best, the injen made the most, and aside from that little bity cat on the stock midpipe, our mid pipes are built really well and everyone will tell you that a full catback doesnt gain you much more over a decent axle back. there again a mid pipe might show gains of 1 -2 hp. so why spend the money if not needed. the header and s pipe are the two biggest draw backs from the stock system. thats why i said i basically had what you were looking for, not exactually, and i dont have a check engine light on, i did the anti fouler trick and it works
and some type of axle back, or the megan drift spec catback. the megan s pipe also is just a little cheaper then the invidia and they produce nearly the same numbers, plus i think most places are still out of stock on the invidia. the megan header makes good hp numbers but the total spread isnt that great do to the quickness that it turns from 4 to 1, a dc or someting like i have makes overall more power and torque cause each running is longer and allows the exhaust to equal out before being collected and sent out the muffler. check out the part round up thread, youll see what i mean.
the alphawerks is no longer made, but there is a company that makes one just like it and for a good deal. ill search and when i find it ill post up. but theres a thread here about that as well
the header is made by dme
heres the thread on it:
https://www.scionlife.com/forums/vie...275&highlight=
believe me, i had a dc on at first, nice header but the one thing i noticed was the sound, the exhaust note was real rasp and you could hear the motor under the hood, as if the header tubes were to thin, when i replaced it with the alphawerks the exhaust note cleaned up and under the hood sounded like a stock car again, still had a little rasp, but then i installed the s pipe and now its just sounds really throaty, very little rasp with the s pipe on, thinking about doing the resonator trick and see if i like that. and with the pulley youll love how much faster it revs
