Ingalls Engine Torque Dampener Scion tC "STIFFY"
Old 12-11-2006, 04:33 PM
  #61
BOXMAN's Avatar
TTT for questions or if you need a site for best price PM me
BOXMAN is offline
Old 12-12-2006, 07:15 AM
  #62
SmooVtC's Avatar
so is there an actual DIY on how to adjust the damper? what tools are needed?
SmooVtC is offline
Old 12-12-2006, 12:55 PM
  #63
web
web's Avatar
They tell you that you need a special tool and what not..................I used 2 adjustable wrenchs that can expancd to over 1 inch. That's all and I've adjusted it multiple times
Loosen the small jam nut and measure the space between the two larger nuts. Stock it should be set at 14mm so tighten the top on closer to the center body of the damper to make it stiffer or leave it at 14mm and make sure to retighten the smaller jam nut against the top large nut. Don't go past 15mm b/c it will be as if you have nothing on your engine. It'll feel stock. The tighter it gets, the more inner vibration you get and when it's cold, the more noise you will get until the hydrolic fluid heats up and lubricates the acctuator inside the body of the damper. I've got mine at 13 and am satisfied with it. Have had it for about 4 months and put about 15K on it
web is offline
Old 12-12-2006, 01:26 PM
  #64
chrischoi's Avatar
but be careful with it. it could break.
sarcasm...
chrischoi is offline
Old 12-12-2006, 01:27 PM
  #65
web
web's Avatar
sarcasm...
web is offline
Old 12-12-2006, 01:28 PM
  #66
chrischoi's Avatar
or am i being serious?
Old 12-12-2006, 01:29 PM
  #67
web
web's Avatar
who knows right?
web is offline
Old 12-12-2006, 01:31 PM
  #68
chrischoi's Avatar
well.. maybe i gave it a mean look one day and it just broke. like broke broke. and i sent it to medical rehab... then the looney bin....
grant, i sent you a pm.
Old 12-12-2006, 01:32 PM
  #69
web
web's Avatar
Where'd it break at? What point of the damper broke? The braket on the strut mount, braket on engine mount, or connecting ends of the damper to the braket mounts? Or....just the damper itself internal?
web is offline
Old 12-12-2006, 01:36 PM
  #70
chrischoi's Avatar
i'm gonna have to leave you hanging on this one.
Old 12-12-2006, 01:37 PM
  #71
web
web's Avatar
haha, ok.................whatever makes you feel better. Good luck getting it fixed or replaced.
web is offline
Old 12-12-2006, 02:19 PM
  #72
chrischoi's Avatar
i never said it was broken. so it could be fine, it might be broke, i might not even have one.
Old 12-12-2006, 02:24 PM
  #73
web
web's Avatar
haha
web is offline
Old 12-12-2006, 03:02 PM
  #74
BOXMAN's Avatar
Chris. Pm me your info. I am sending you out a replacement ETD. See how easy that was.
BOXMAN is offline
Old 12-12-2006, 03:04 PM
  #75
web
web's Avatar
haha, well, now you have one and it was broken but...........now you get a new one .............that's cool that they replaced it though.
web is offline
Old 12-12-2006, 03:47 PM
  #76
chrischoi's Avatar
i thought it was quite tedious. let's see.... 6 months. 5 emails. 2 phone calls. even messages on myspace... and 6 months later... i find out they changed the rep guy... which is you... and now you're fixing what they should have done back in june.
so ok. it wasn't ingall's. it was the last rep. but we'll see what happens.
Old 12-12-2006, 03:51 PM
  #77
BOXMAN's Avatar
Chris you make it very hard for a company to want to help you out. The issue with the jam nut happens due to improper adjustment procedure being followed. Ingalls is willing to loose money on a new ETD for you and all you can do is come on here and BASH how long it took? Most companies would have said user error you are on your own. SO whats the deal. Also the Ingalls MYspace is locked due to password issues so we cant log on to respond or check anything on that site sorry.
BOXMAN is offline
Old 12-12-2006, 04:37 PM
  #78
chrischoi's Avatar
i wasn't bashing the company. i said... the last rep. you said it's easy... i was blaming the old rep for making it this way... nothing against the company.
Old 12-12-2006, 04:40 PM
  #79
chrischoi's Avatar
it's nice to know the old reps gone and we have someone like grant that takes care of the old reps mistakes. you're doing a good job.
  #80
BOXMAN's Avatar
Ok point understood and yes Ingalls last rep left some people hanging without filling anyone in when he abruptley quit/wasterminated. Sorry as stated Chris I have packaged up your replacement ETD and it will be going out today.
***This is a special case*** All other Ingalls ETD warrenty cases need to follow the correct steps to get a replacement or have their unit serviced***
BOXMAN is offline
Quick Reply: Ingalls Engine Torque Dampener Scion tC "STIFFY"
