injen CAI question?
yeah you'll prob have to undo a few things under the bumper and possibly the wheel well but I think if you take a few bolts off the bottom you should be able to get your hand in there enough to yank it out....
Is there pics of an install online? I dont want to take my car apart each time I clean the filter. I have read some things that you have to take the front bumper off to install it. Some other cars you just havet to fender well out...
for me it was a pain in the Glute... it took anout 2 and a half hours....I took off half of the bumper, the wheel as well as the wheel well... it took for ever!! to do it right (no scratches...) thats what you got to do... now thats not to say itwasn't worth it! id deff was...esp when you take off that little black cover down at the bottom of the bumper, the air gets sucked into the cab...as well as it sounds soooooo good! besides...you paid for the whole thing why not use it! if not ...I'll buy it off you...lol
Just take the front bumper off... it's a piece of cake to do.... don't let other posts fool you.... Then the filter is right there to be worked with...
I love my CAI and take my bumper off all the time...
2 1/2 hours?? WOW!!! This must be your first time doing that cause it doesn't take that long at all even to do it "right". All you really have to do it take out the fender liner. It's mad easy. Besides how often are you gonna clean it. Even if you're really worried about it you'd do it like once every 3 month but realistically twice a year. I swear some of you guys will try to scare the hell outta ppl. Just cause you're slow doesn't mean things are hard. Holla!!!!
Originally Posted by jmiller20874
Now I know for sure I'm getting the Weapon-R. Thanks guys.
don't get me wrong! I love the Intake..I would have gotten this one nomatter how long it would have taken...but hey if a little work makes you sweat, this prob isn't the intake for you...... but its real niiiiiccccce!worth every drop of sweat.
Not that a little work is the problem. Taking the car apart repeatedly for a routine maintenance issue is too much of hassle considering another product giving the same performance results doesn't require anything to be removed from the car to be maintained. Time is money afterall.
I buy parts based on 3 things; performance, price and maintenance req. It just seems the Weapon-R edges the Injen out in all 3 categories, that's all. I don't care what name is stamped on it.
I only said that you got to take the car apart when you install it!... otherwise it's literaly 4 bolts and a screw or 2...its all in knowing how to put it back together.... i'd prob take like 15-20 mins...less if you know what you are doing.
What do you have to take out to clean the filter? the fender well???
most likely not... if anything all you have to do is un hook 2 bolts of it... you can get to most of it through the bottom of the car by undoing a few hooks...I'd show you picutres of what I mean if I wern't so darn lazy....if you get down under there you'll see what I mean...
Originally Posted by tc913
yea.....taking off the front bumpers isn't very hard. There's just a couple of bolts u gotta lossen and pop that sucker off.
Well I would have the dealer install the CAI, but if I have to take the bumper off everyrtime I want to clean the filter, now that is a different story. What about sucking water into it because of the location. I live in houston where it rains a lot...
im sure not that much water would go in because it is covered by that plastic on top of the wheel and on the fender. in case water does go in, buy a bypass vlave, 3 inch byapss by aem should work from what i have heard. im thinking of buying one too when it starts raining here in cali.
the whole point of a CAI is to take advantage of the cooler air down under the car...the only way you will "hydrolock" is if you go through a huge puddle and it gets dipped into the water... just getting it wet is not going to hurt it...I mean, not only does the water have to go up the tube it also has to go upinto a HOT tube... if little bits of water get into your pipe its most likley to evaporate....water will only get to the TB if there is no other air to intake...(I.E. submerged or dipped filter)..
