Injen Hydroshield
Old 01-17-2007 | 03:23 PM
spECIal's Avatar
tru tru.
i have a guy in my car club that im sure knos how to do it cause he add everything to his car himself (STI). but im jus scared if somethin goes wrong. it would be easier to blame the shop then to blame a person.
i dunno
Old 01-17-2007 | 03:25 PM
web's Avatar
web
I can understand that. I simply followed the DIY that came with my intake and found it quite easy. Just have to remember what splash gaurd bolt goes where when you're putting it back together. There's only 6 i think so just lay them out in the manner that they came out and it's easy. I'm installing the Injen intake and HIDs on Phillyphil06's tC this weekend. Your friend with the STI should be able to do it. It's really straight forward.
Old 01-17-2007 | 03:27 PM
web's Avatar
web
whatever you chose to do, good luck though Just remember that if your CEL comes on and you went to the shop, they probobly didn't disconnect the battery. Common error. Disconnect the negative for about 5 minutes and then reconnect it. Reset your windows and roof and all, but your CEL will be gone. Let your engine idle for about 5 minutes and drive it for about 20 minutes doing both normal and some fast driving. It just helps readjust the ECU from being shut down.
Old 01-17-2007 | 03:30 PM
spECIal's Avatar
yea.
damn, u should take a trip out here. lol
nah, but the thing that is stoppin me is that u have to take off a tire. if it wasnt for that, i'd have him do it.
i had an 02 sentra se-r b4 the tC and he installed an aem on that wit no probs.
i guess i jus worry to much.
does the DIY come with the intake when u buy it?
like it tells u EXACTLY how to take the wheel off n stuff?
Old 01-17-2007 | 03:35 PM
web's Avatar
web
It won't tell you about the wheel and instructions for that b/c that should be common knowledge. I'm not saying that you should know though, just speaking in general.
Taking the wheel off is simple:
-Loosen the lugs off of the driver's front tire.
-Jack the car up from the center support that runs right next to the oil pan.
-when you're done with the intake, place tire back on hub while car is in the air still
-put one lug at a time back on with your hands
-tighten 1 or 2 as tight as you can holding the wheel stationary and using your torque bar or tire iron
- lower car back until the tires touch (not all the way down, but enough so that it doesn't spin)
-tighten all the lug nuts to about 80-100 lbs/ft (as tight as you can with your tire iron)
-lower car, and you're done
Old 01-17-2007 | 03:37 PM
web's Avatar
web
the intake should come with instructions on how to remove the old intake and install the new one though. I am going to scan my K&N instructions and post them up later tonight on here and my other site, www.clubsciontc.com That should help a lot of people.
Old 01-17-2007 | 03:40 PM
spECIal's Avatar
alrite.
i'll email this thread to myself.
thanx again for the info
Old 01-17-2007 | 03:41 PM
web's Avatar
web
NP, PM me if you have questions and maybe I can try to get some pics and write you some steps on how to help you out.
Old 01-17-2007 | 03:43 PM
spECIal's Avatar
alrite, thanx.
im gonna order my intake tomorrow from trdsparks.
then sometime next week or the week after i myte take it to get painted.
so the install wont be for about another 3 weeks
but if i decide to have my friend do it, and i need help, i'll let u kno
Old 01-17-2007 | 03:45 PM
web's Avatar
web
sounds good..............BTW, how much is TRD sparks charging you for the INjen? they are expensive................I can find you one cheaper if you want...............brand new too...........06 or 07?
Old 01-17-2007 | 03:48 PM
spECIal's Avatar
280 free shipping.
is coo. imma go with them. i said i was for the past couple of months now.
i've seen some cheaper to, but its all good.
thanx though
Old 01-17-2007 | 03:49 PM
web's Avatar
web
aight cool. Good luck
Old 01-17-2007 | 03:53 PM
spECIal's Avatar
yep yep
Old 01-17-2007 | 04:06 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Tasha if you need help with the install just hit me up, I'd be happy to help out. It'll save you a bill as well. :-P
Old 01-17-2007 | 04:11 PM
spECIal's Avatar
where are u located?
well, where is duarte?
Old 01-17-2007 | 04:12 PM
spECIal's Avatar
have u installed the injen b4?
btw
HAPPY 21st
and no alcohol
Old 01-17-2007 | 04:49 PM
MTcX's Avatar
Scionetics
even on surface roads you can hydrolock. When I had my 98 Eclipse i was driving at night and there was what looked to be a small puddle in the road and when i drove through it the engine stalled and hydrolocked. Ended up blowing a rod through the pan and destroyed the engine.
The bypass i dont believe is completely safe and neither is the hydroshield, but they are still good to use. The AEM bypass will not work on the Injen CAI intake without modification to the intake, I've already looked into it.
GOOD LUCK!
Old 01-17-2007 | 04:52 PM
Fsu1dolfan's Avatar
GOOD LUCK!
Where the intake sits on the Eclipse and where it sits on the tC is a world of difference.....
web's Avatar
web
If you had the CAI on your eclipse I can understand why that happened. It runs right down the center of the motor and off to the driver's side near the bottom. The problem with the eclipse is that it has no under splash gaurd. My friend's got a 98 GS and it's the same way. We built a sheet metal splash guard to mount under it and it works great. The tC is shielded from the under side.
Old 01-17-2007 | 04:55 PM
spECIal's Avatar
o, i forgot to mention.
i will also be gettin a trd or hotchkis drop in the next couple of months.
since i'll be lower, will this bring a definite increase to my chances of hydrolocking?
