injen intake and exhaust
i got a injen cold air intake and just bought an injen cat back exhaust and i cant seem to find any horespower/ torque ratings. does anyone have any idea of what together the increase might be?
I don't know what the Megan headers actually dyno for... but I'd guess no more than 10 to the wheels from that combo.
I'm just guesstimating on that though, so I could be off.
You're not going to get that much gain with any bolt ons like that. Maybe with the proper intake, header, full exhaust combo, you could maybe get to 20 whp.
none of that is going to mess up my air fuel mix right?? i dont know if the make some kind of new way to get the mix to be close to factory but i do know it isnt good to have the mix to far off right?
Injen's "catback" exhaust is actually an axleback. (A "catback" exhaust would include a replacement for the midpipe as well.) An axleback replaces the chambered/baffled (i.e. restrictive) stock muffler with a straight-through muffler. It will give you more than 1whp, any axleback will give 5-6whp on an otherwise stock car.
https://www.scionlife.com/forums/viewtopic.php?t=80070
Your Injen intake gave +8whp when setup with the Alphawerks header.
https://www.scionlife.com/forums/viewtopic.php?t=92108
A header will give ~7-8whp when setup with an axleback.
https://www.scionlife.com/forums/viewtopic.php?t=82724
However you will need to buy a new resonator (which is actually another straight-through muffler) to combat the raspy noise which results from adding a header to this car.
An s-pipe will give almost no gain on an N/A tC, and is not worth the $150-200 price.
I have specified the above hp gains with their setups because mods are not additive and every intake/header/exhaust component is designed as a single bolt-on. Since no one makes a tuned I/H/E system everyone will get different results from mixing & matching bolt-ons from different companies.
If your mileage doesn't change much and you don't get a CEL, your air/fuel will be fine. If you're still concerned about it you can buy a fuel management system (Camcon, E-manage, etc.) and have it tuned by a professional on a dynamometer. However, this gets to be very expensive unless you can get free dyno time, so almost nobody invests in fuel management unless they have installed a turbocharger.
carid
02-09-2015 01:49 PM
arinvolvo
24
11-02-2003 05:30 AM
