Installing header / oil pan, need gasket sealant?
Old 06-19-2006 | 02:28 AM
mike6789k's Avatar
Default Installing header / oil pan, need gasket sealant?
Do you need to apply gasket sealant on the gaskets when you install a new header? (i know you dont need to for the bottom connection, but for the connection to the head you might?)
Also, what about an oil pan? Does that need a gasket/sealant too? which side of the gasket do you put the sealant?
I have this yellow goopy stuff called methyl ethyl keytone, is that good enough for a header / oil pan?
Thanks alot!
Old 06-24-2006 | 09:08 PM
mike6789k's Avatar
bump O.o
Old 06-24-2006 | 09:14 PM
leastbay's Avatar
dont use any gasket sealant on the headers at all just the header gaskets, as for the oil pan you'll have to check with toyota bc Im not sure but it probabally just uses a gasket without sealant also.
Old 06-24-2006 | 09:37 PM
PghtC's Avatar
there is no oil pan gasket at all. It is high temp RTV silicone sealant. Orange stuff.
Old 06-24-2006 | 09:47 PM
mike6789k's Avatar
ok, so headers just have a gasket, and oil pan uses orange sillicone sealant! got it! thanks
Old 06-24-2006 | 09:59 PM
leastbay's Avatar
no oil pan uses an oil pan gasket no sealant
Old 06-24-2006 | 10:42 PM
PghtC's Avatar
have you ever taken the oil pan off?
There is no gasket. Just an adhesive silicone sealant. And it is a B!tch to get off of there!!!
Old 06-24-2006 | 10:43 PM
leastbay's Avatar
i never have thats why i said check with toyota I assumed it was a gasket though
Old 06-24-2006 | 10:44 PM
PghtC's Avatar
nah, just sealant...
It's all good.
Brammi
11-13-2016 04:46 AM
cessblood
09-15-2015 07:50 AM
my06tc
06-25-2015 01:18 AM
Frustratez
02-26-2015 05:03 PM
TheRedBox
31
12-02-2003 05:53 PM
