Jet V Force Plus
Jet V Force Plus
Anyone check this thing out yet. I think Jet has a pretty good rep, up there with hypertech, edge, superchips. This might be the first real chip for scions. This is not the typical crap you see on ebay. I has a nice display too, looks to be about all the same functions you get with a scangauge plus the power gains. These power programers usually advance the timing and tweek the A/F to give a nice gain. I had a superchip on my last car that was a Ford.
http://www.jetchip.com/V_FORCE_PLUS.asp
I emailed them two days ago or so. I am trying to dig for more info like whether its plug and play or you have to splice your wires. I was also asking if they have any dyno results, and if it wuld fit the 08 xb seeing as they have the same motor. I'll post up soon as someone gets back to me.
I think the bigger question would be : How is this different from a Greddy eManage, or other type of advanced standalone air/fuel/timing controllers already available?
Much like a 6 speed transmission, a "chip" for a naturally aspirated scion is not something people are chomping at the bit to develop. If you absolutely insist on something that reprograms your fuel maps, you'll need to go with something universal, and something that hopefully won't be over-ridden by your OBDII emissions system.
Originally Posted by mystik
why would you want to tune up ignition timing...if your car starts fine, then your ignition timing is fine...
more power can be made on top of AFR tuning if you advance ignition timing throughout the RPM band on naturally aspirated setups.
Its a piggyback system and you do have to splice wires... Honestly, we were discussing it on some of the other forums and I think on here for the xD and the more I read and research the more I realize it would just be better to go full stand-alone for anything you're doing...
CinSity Scions
In the post in xd subforum on this same topic we discovered Jet also offers an ecu flash. I emailed them it is $399. Apparently they replace a chip in the ecu and flash the new chip with the maps. No one has tried it yet, and I tried asking them if this means the flash will tune in closed loop but did not get an answer. Anybody have any ideas/info on this? Could it be that Jet of all tuners found a way too crack our ecu? They offer custom tunes by request, I don't now if that actualy involves dyno time or not though.
WRX1316_TcVicent
07-22-2021 06:06 PM
Subaru86
07-31-2015 04:33 AM
