K&N CAI Installed.
Make sure to let it idle for a while with occasional revving so the ECU will pick up the changes before you go powering down the road. The instructions on my Injen CAI and from what I've heard from knowledgable sources say 15 minutes. That's what I did and haven't had any CEL issues...
Originally Posted by BigKid
I was wondering for those of you that have already installed your intakes...was there any problems with any electronics afer re-installing the battery terminals.
the idle is exactly the same as stock too.
It was an easy install and resetting the windows only took a few sexonds. THe rubber hose that came with it was a bit long so I cut it shorter and used the exter to keep from havieng a rub point on the second pipe when it goes into the wheel well. It took me like a little over an hour. I did some how loose one bult and put a temp in until I can get anouther long enough to properly replace it.
Originally Posted by LIKE OR AS GOD
..and used the extra to keep from having a rub point on the second pipe when it goes into the wheel well.
Originally Posted by English
maybe you should complain to K&N, it really shouldn't be rubbing against anything if it was installed/engineered correctly
i didn't even mention it in my first post, because when someone on this board see's something like that rumors start going around about how the intake sucks and it gets way out of hand.. for example, when someone put the WR intake on incorrect the CEL came on, then everyone thought the WR intake was crap even though it wasn't.
also, i wanted to mention that when something is in there preventing the rubbing you can't see it at all when you open the hood.
Originally Posted by f1nch
yes.......if you drive into the ocean....hydro-lock is a myth..dont worry about it...
Originally Posted by ToBeeyach
I'm going w/ WR SW. Better power gains right off the bat
considering you can take apart the K&N CAI and make it into a short ram for no cost at all, why on earth would anyone choose the WR intake?
Approve / Not Approve
I am looking at this CAI on ebay..
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I would like to know your opinions on this as I am thinking of purchasing it.. there is a new version which is nearly $200 but I would prefer this one as it's not expensive..
thanks
thanks
Re: Approve / Not Approve
thanks
thanks
here is another one that the ebay guy sells
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
how the hell would a carbonfiber filter work isnt that like making an aluminum box and saying its a filter? and that pipe wont even reach the throttle body
K&N rocks
the install took a little long because i dropped the allen key into the engine bay, and it took me 1 hour to find it, by the time i finished the install it was 2 am but i still took it out for a drive. let me say this car sounds like a beast under full throttle now, you can notice the intake come to life once the vvt-i kicks in. theres deffinately more power because i can now hit 80 mph in 3rd gear, where before i was in the 70-72 range. i also got it some how for 129.99 from suprastore, but that was an error and it has since changed, anyways see you all in EXPOSED daytona,
