K&N or TRD drop in filters
I think they usually claim 5hp or so, but the real improvement is on the wallet. I have a k+n in my truck and it has paid for itself because it is reusable. Especially wise if you drive in dusty areas.
K&N filters are a religious issue and the subject of endless debate.
I used them when I was racing motorcycles off-road and they were the best for that application. The reason is that they would never clog up and cause a DNF. The down side of this is that K&Ns would pass a lot of fine particulate, but since I rebuilt my engines frequently I didn't care. DNFs don't pay purses, so the emphasis was on finishing the race. The fact that K&N paid contengency money was also a factor.
For a street driven car I wouldn't run a gauze filter. You can buy a heck of a lot of stock paper filters for the cost of a rebuild. Paper filters provide a physical barrier to all particles above a certain size, which is what is needed for long engine life. They aren't "kewl", but they are the best for the job.
George
George
George
George
Originally Posted by nero tC
so basically the K&N and TRD air filters are pointless unless you want a little growl? i was about to get one. but its better to stick with the stock air filter?
I have used the K7N drop ins and the full kit (Sonoma 4.3L). The full kit with low drag toobs give you a good sound and I almost unnoticeable low torque increase. Yes the are reusable BUT they do not filter out the air pollutants nearly as well as a paper filter, this is why it has more air flow. To keep the motor from wearing as fast use the paper filters.
K&N PART NUMBER
Anyboyd has the K&N drop-in filter part number?
Thanks
PS. I am a big fan of K&N filters. They are great. Not to the point that there is difference on a dyno but definetely you can FEEL the difference. At least this was the case in all the cars I've driven so far.
Thanks
Re: K&N PART NUMBER
Thanks.
Re: K&N PART NUMBER
Thanks.
"Feel" meaning responsivenes; you press the pedal to the metal and the torque appears that little split second sooner....
K&Ns hav as many followers as critics. Buy one, they are not that expensive and you will know right away. Just do not put the K+N sticker OUTSIDE the engine bay 'cause that's pure "rice" and you definetely want "race" not "rice"
K&N AIR FILTER PART NUMBER: 33-2252
K&N part number is 33-2252
http://www.knfilterchargers.com/sear...x?Prod=33-2252
33-2252 Product Specifications
Product Style: Panel Air Filter
Height: 0.938 in (24 mm)
Outside Length: 11.375 in (289 mm)
Outside Width: 5.938 in (151 mm)
Filter Re-Oiling Amount: 0.83 oz (24 ml)
Weight: 0.8 lb (0.4 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
OTOH, if the filter had a finer hole pattern, it would filter slightly better, but the particles filtered would be too small to make much difference.
Now, there are "racing" oil filters (Fram HP-1, for example) that are built to take more internal pressure than stock filters, but a stock Scion doesn't need this capability.
I'd say that if you change oil and filter at the recommended intervals, the standard filter is fine. I don't see any advantage that the TRD part could have over the stock part.
George
George
airmankevin1
02-14-2018 01:23 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
02-12-2015 01:41 AM
Godfryness
01-02-2015 11:18 PM
