lightweight flywheel
Old 01-28-2011 | 01:39 AM
austinasto's Avatar
Default lightweight flywheel
okay, im getting a lightweight flywheel but dont know what weight I should get. my car is still my daily driver so i dont want it too light, but i do want it light enough to feel the difference in acceleration. and also while im at it. should i go ahead and get a new clutch also? right now eveything in my transmission is stock.
Old 01-28-2011 | 02:15 AM
my06tc's Avatar
if its a DD which means a street car then 12lbs will be fine for you,you will still notice the difference,ill rev alot quicker,if your going boost then yea youll need a new clutch,but if your not planning on going boost then stock will be fine unless you wanna upgrad while u have the tranny apart doing the flywheel
Old 01-28-2011 | 02:31 AM
austinasto's Avatar
yea ill most likely want to since im coming up on 80,000 miles soon. would you happen to know if the clutch feel is any different?
Old 01-28-2011 | 03:01 AM
engifineer's Avatar
I would change the clutch at that mileage since you have it apart. It should last a long time past where you are at, but still, at 80,000 and the tranny out it just makes sense. You dont need anything stronger than oem spec really, so just get a good quality clutch.
And the advice above is true regarding not going below a 12lb flywheel. You would notice a bigger change in driving habits needed if you went much lighter. You will need to adjust your launch habits already with the 12lb, but it should be a better setup for the average daily driver.
Clutch feel should be the same given the clutch you get is similar to stock. Obviously if you get a different clutch it will feel different.
Old 01-28-2011 | 12:24 PM
my06tc's Avatar
yea if your coming up on 80k and you have your tranny apart then yea,change your clutch,and yea any aftermarket clutch will feel different,alot stiffer,but if you dont plan on going FI,then get a OE clutch
WRX1316_TcVicent
07-22-2021 06:06 PM
Mjdavis1994
09-21-2015 04:42 AM
5N1PE5
08-03-2015 11:25 AM
Subaru86
07-31-2015 04:00 AM
Quick Reply: lightweight flywheel
