Loud noise when slowing down!
Old 05-02-2010, 09:52 PM
lltysonll's Avatar
is this what your hearing?
http://www.youtube.com/watch?v=1h52A...eature=related
lltysonll is offline
Old 05-02-2010, 10:06 PM
pioneer1976's Avatar
i doubt its coming from the gearbox. next time you slow down and you hear the noise slowly turn the steering wheel alittle to the left and right and see if it goes away.. i think your having a bearing problem..
pioneer1976 is offline
Old 05-03-2010, 02:20 AM
KillaSpiceTSW's Avatar
It happens when im NOT pressing the brakes or if I do press the brakes, noise doesnt change. It doesnt matter if I go straight or cut the wheel to the left or right, it still makes the noise. Doesnt matter if the dang car is on or if I turn it off and coast it down the street. Doesnt matter if its in gear or if I throw it in neutral and once again coast down the road. Doesnt matter what I do that damn noise is mostly heard starting around 25mph and all the way to a complete stop. I think the reason I cant hear it while accelerating is cuz I have an Ingalls stiffy, ES Motor Mounts, Raceland CAI, Tsudo 4-2-1 header with spipe and HKS axleback so its extremely loud lol! Its best heard when I coast it in neutral with the car off or on!
KillaSpiceTSW is offline
Old 05-04-2010, 12:52 AM
tCjosh's Avatar
check your brakes as someone said earlier in this thread... might also be something that got binded up inbetween something. i'd just take the brakes apart and clean/grease everything up right and see if that helps some....
or the tire/tires are rubbing on something????
tCjosh is offline
Old 05-04-2010, 03:04 AM
Actually we jacked the car up and we each took a turn getting underneath the car while the other one spun the tire and when the tire was spinning, the noise was coming directly from the gearbox. I bought some tranny fluid today and plan to change it later this week to see if that helps but I have a feeling a tooth broke off one of the gears or something like that in the gearbox! I checked the entire brake system, tires, suspension and found nothing!
Old 05-04-2010, 05:04 AM
rangerryda's Avatar
For your sake, I hope its not the tranny. It's a PITA to get out.
rangerryda is offline
Old 05-04-2010, 08:36 PM
tCjosh's Avatar
I just realized one more thing you could also do... this happened to my old car and it was making some loud ___ noise.. get back under the car and locate the flywheel then see if you can spin it freely... if you can then the problem is the flywheel bolts are broken off... not sure if this is the same problem you're having but its worth a try...
pretty uncommon, i think but its something else that you should also check.
tCjosh is offline
Old 05-04-2010, 09:34 PM
Yeah bro ill give that a look on Friday when I change the Tranny fluid. Thanks
Old 05-05-2010, 12:57 AM
rangerryda's Avatar
As I recall, getting to the flywheel requires taking off the transmission...
Old 05-05-2010, 02:19 AM
My bestfriend who is a mechanic said that it cant be the flywheel anyways. Hes the one that got under there with me that day. He said he knows what that would sound like if it was flywheel, and its not that. Maybe its cuz I drive like a dumb@ss most of the time and really did break something, who the hell knows!
Old 05-05-2010, 06:13 AM
rangerryda's Avatar
I say drain the trans fluid and look for any shavings etc. Replace with OEM Mobil 1 75w-90, 3 qts and see what happens. Either way it won't hurt if you have near 75k on the car.
Old 05-05-2010, 07:51 PM
I hope I dont see any shavings lol... I actually already bought 3 bottles of Royal Purple 75w90 a couple days ago, I love RP products.
Old 05-06-2010, 06:00 AM
rangerryda's Avatar
I had RP in mine for about 5k. I hated it. I've used some of their other stuff but so far, I've seen 3 different brands in the tranny and Mobil 1 OEM is the best but it all depends on your car. Some cars like it, some drivers like it, I couldn't stand it. Felt like I only had water in there lol.
Old 05-06-2010, 07:45 PM
Oh dear I hope it doesnt feel like water, Ive really respected RP for quite a while and I hope this doesnt make me change that feeling!
Old 05-06-2010, 08:07 PM
tC_Crisis's Avatar
have you resolved this issue?
tC_Crisis is offline
Old 05-07-2010, 01:09 AM
No sir. Tomorrow im changing the tranny fluid. I was waiting for my day off. If that doesnt solve it, then im screwed cuz the noise is coming directly from gearbox!
Old 05-07-2010, 02:29 AM
rangerryda's Avatar
New clutch and trans swap would be cake if done at the same time since it has to come out anyways
yupinmytC
22
07-27-2024 07:08 PM
kb1sxv
10-21-2015 05:00 PM
Klashan
09-24-2015 12:39 PM
prescottn
09-22-2015 01:30 PM
mcnick0495
Scion tC 2G ICE & Interior
09-08-2015 02:58 PM
Quick Reply: Loud noise when slowing down!
