M/T Fluid Change??
M/T Fluid Change??
so i went to the dealership for my last once over with the car before i hit 60K, im at 59,850.
They told me my M/T Fluid is "real bad."
Is this really necessary to change for 70 bucks @ 60k...or is it something that i can prolly do w/ the right tools, 20 bucks worth of Fluid, and 2-3 beers??
Yea i fly through the gears on occasion at least once a day
u can do it yourself. i change the m/t fluid every 30k miles.
buy 3 bottle of Eneos fluid
http://www.amazon.com/gp/product/B00...ef=oss_product
and follow this DIY
https://www.scionlife.com/forums/tc-tech-diy-1818/transmission-flush-manual-redline-mt-90-a-59661/
and follow this DIY
Changed mine at 50k ish and the old fluid was really stinky. It's a easy procedure that takes an hour if it's your first time. My recomendation is to get some wood about an inch or 2 thick and drive onto it(ghetto ramps) but it is doable without them too. Also, when you open the drain bolt the fluid gushes out and gets on everything so position your drain pan accordingly.
Changed mine at 50k ish and the old fluid was really stinky. It's a easy procedure that takes an hour if it's your first time. My recommendation is to get some wood about an inch or 2 thick and drive onto it(ghetto ramps) but it is doable without them too. Also, when you open the drain bolt the fluid gushes out and gets on everything so position your drain pan accordingly.
Thanks for the DIY post BTW
RY_TC07
07-18-2017 05:18 PM
kleecker
9
05-26-2015 12:12 AM
mrsocks
01-20-2015 01:29 PM
