Making changes after the emanage
if i tune the emanage, and then i install another engine part (like a header)... do i need to tune the emanage again, or it will be doing the same benefit?
for example... if i install the emanage and tune it. but after a while i decide to install a header, intake, and exhaust... the benefits of the emanage will be still on?
tune's are done for a specific setup. if you change that setup, naturally you would want to change the tune to match it. is it required? no. is it recommended? yes. in a case where you're leaning out the engine, then you add another component which leans it out even more, it may even be dangerous not to retune it,.
rain7905643
12
06-13-2018 05:34 AM
TheTripleC
01-04-2015 06:46 PM
