> Mid-Pipe Question <
Old 03-10-2008 | 06:23 PM
TeeCizzle's Avatar
Default > Mid-Pipe Question <
Aight so...Just want to see other peoples opinions or thoughts.
I have the DC Sport axle-back exhaust...and I have an AutoMagic!
I heard if I change my mid-pipe to a different one..It wont sound Raspy and NO CEL..is that correct??
The stock mid-pipe has a secondary cat too?......whats the diameter?
if so..its ok to remove it??
Aight...well Thanks!
Old 03-10-2008 | 06:30 PM
tCmaniak's Avatar
Default Re: > Mid-Pipe Question <
as far as swapping your midpipe, as long as you dont have an aftermarket header, your probably gonna be ok. Yes the stock midpipe has a second cat and it WILL be removed if you get a mid-pipe. just put a high flow cat on your mid pipe to replace the secondary and your good to go.
Old 03-10-2008 | 06:43 PM
caveman's Avatar
1UP Crew
The diameter ranges from 2.0x to 2.25, with a secondary cat, and a resonator....and there is no problem deleting those as far as CELs are concerned because the last sensor is the o2 on the s-pipe...
Old 03-11-2008 | 02:33 AM
BlckdOutTC's Avatar
^^x2. as long as the stock header is in you'll be fine
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
jairolla_89
04-02-2015 09:41 PM
Scionxa180
03-13-2015 04:39 AM
xBassist
9
01-21-2004 07:34 PM
Quick Reply: > Mid-Pipe Question <
