midpipe hitting bottom of car
Team Scionara
So before i had a 2.5 inch s-pipe my mid pipe would hit the bolt on a heat shield every once and a while. after it is installed it shakes like crazy and is constantly hitting it. Any one else have this problem? not only is it annoying i don't want to put a hole in my midpipe! if you do have this problem how did you fix it? And its the tsudo mid. Is that one just sucky and hits and others don't?
and the bolt that it's hittting is ground down to just the nut on it. theres no threads showing past that.
I posted thiks already in drivetrain and power but the fi forum is the only one that really sees any action so I figured id post it up here. I have a day off tomorrow and would like to fix this if I can.
Team Scionara
what did you torch? I don't have a bolt on the heatshield. Just the nut holding the heatshield up. Should I just cut that off too? What is the point to that heat shield anyways?
Team Scionara
Yeah I hate it. Its make not want to drive my car. I have it bungeed to hold it place a little bit witbh that black brace going across the middle of the midpipe which probably isn't a good idea. With out that its just ridiculous
I have the same mid n same problem, at first i put high temp silicone to dampen the rattle, but after i put my concept g on, it just kinda disappeared. I think tsudo is a hit or miss product, some work, some don't, so it seems somewhat inconsistent when it comes to buying their products.
sorry to bring this up again but i have the same problem. just bought the tsudo mid and that ____ be clanking and rattles. its so annoying and like u said makes me not want to drive the car. did you ever get it fixed?
Team Scionara
mine i had to cut the bolt on my heat shield for my trans too. it rattled there because my resonator was hitting it. no problem on the brace bar though. mine happened alllllll the time. the most was at idle and getting into gear though.
Why is this in here? Rnt you boosted?
