MMW CEL Eliminator vs Antifouler vs EManage
threadlocker is the best way to go to keep that o2 from comming loose... but if you still get a CEL after all is in and tight... try putting a third antifouler in.... i actually had a CEL come back over and over again till i addded a second untouched antifouler... havent had it come again since...
O2>bored out antifouler>untouched x2>spipe
Yeah, as the S-Pipe sits now it will not allow me to add 2 antifoulers, let alone three. I don't see how I can do this...I will recheck my S-Pipe/mid pipe install to make sure I am getting all the room I can out of it, but I dont think that will be the issue...I dunno what I can do about this =/
Anurok
Anurok
sup man, i've seen you around before.. i think that was your car at plaza bonita a couple months back..
im running the same setup as you.. except i have a tsudo n1 catback. i'm running the antifouler mod on my invidia s-pipe.. not enough room to fit 3, but it's a perfect fit for 2. i havent had a CEL for approx. 4000 miles now.
good luck with your o2 sensor, they cost roughly 200 bucks from the dealer.. it's common to strip an o2 sensor nowadays..
yeah, I don't plan on spending that on an O2 sensor. If anything I will either use a thread locker on it, die cut it, or splice a new O2 sensor on it. I have not had a chance to check fitment issues so I am still stuck with the O2 strait in the pipe with no foulers....
What I am thinking of doing is taking a washers and welding it onto the bottom of the bored out fouler to create a tiny hole for the air to come into. I will see what I can do about that...it should work
Anurok
Anurok
yeah...I dont think it is the antifouler though....it is a fitment issue with getting it on down there. I dont have the room to properly fit the fouler. That or I may have fked up my O2 which would suck. Either way I opted out to get the Emanage and piggy back the pos...
Anurok
Anurok
Wrencher
07-29-2015 01:38 PM
umnitza
07-25-2015 07:54 PM
