MMW Header Bolts Question
Hey just bought a use MMW header and the parts that i received were the header and the spipe.
As for the installation are you suppose to use the spring loaded bolts from the stock setup to bolt on the header and the spipe? or does the MMW suppose to come with its own set of bolts that hold on the header and the spipe.
Also as for pieces there is suppose to be a gasket ring from the header to spipe correct?
And last and but not least the stock bolts from the spipe to midpipe are stock polts right.
Thanks,
Jeremy
Thanks,
Jeremy
i have teh MMW header and AFAIK i got longer bolts (very long bolts) and used the stock springs and donut gasket. (i got my header from aroddalobster) but ya once you find a bolt long enough it was cake.... i would try to get pics and a size of the bolt for you but my car is crazy low, and my jack died on me sunday when i was taking my BBK off so theres no way for me to get under my car
gettign longer bolts for where the spipe bolts to the midpipe is a good idea,the ones they supply area hard to get started and on,I used 4" grade 8 bolts from home depot and no problems in over a year.
