Mod Suggestions..
Mod Suggestions..
I wanna keep it NA for now
i have intake and exhaust..
im looking to do s-pipe and crank pulley..
what else would you suggest, or suggest in place of my upcoming mods
If you want to notice your performance increase, go with suspension. Those power mods will get you almost enough power to nearly notice. $1000 on springs, sway(s) and tires you will notice ten times over. Changes the car completely.
I would definetly get the crank pulley. I just got one and I do notice quicker throttle responce. I also have an intake and exhaust. So after you get the crank pulley which is only a little over $100 do what engifineer says and work on your suspension. Thats what Im going to do
+1 on shifter, check out www.doctorisotope.com for his gearswitcher. Don't forget the cable bushings, those are an immediate and noticable difference. I think even more than the shortened shifter!
Don't forget some sticky summer tires, that will make a massive difference. Probably best way to spend around $500
Bmfxtreme
08-18-2015 01:25 AM
