My cel keeps coming on.
Ok i have k&n intake and AW headers and after i installed the headers with the antifouler my cel keeps coming on i just jeep restarting my ecu to get my gas milege back.. What should i do to fix the problem the .. it comes back on like every 200 miles after every restart.
whoa whoa whoa...
NEVER install the antifoulers on the header. NEVER
I've seen this on the forums quite a bit lately. I really hope you guys realize its the 2nd sensor on the exhaust side (go look at your s-pipe) that is throwing the CEL in the first place.
Kaeon's FAQ : https://www.scionlife.com/forums/viewtopic.php?t=56520 has the anti-fouler trick outlined perfectly. If you follow these instructions you should not have a CEL. If you do have a CEL and have followed his FAQ, then it is likely there is some other problem and you should get the car scanned to see what is really going on.
Originally Posted by matty-tC
whoa whoa whoa...
No i know that i meant if the o2 sensor is broken then i would have to buy a new one and i hear they are expensive... cuz thats what i think it is i hear they are sensitive... and my uncle who installed it is not.
Well, diagnosing what's wrong just by the fact that you have a CEL is like saying "I don't feel well, how do I get better?".
So let's try to figure out what the problem is first, and then worry about prices of O2 sensors these days ;)
Get the code and give us a call we maybe able to help. We stock both 02 sensors if you need one. The front 02 shoudl not throw a CEL unless it is faulty regardless of A/F. The rear sensor does chane the gas mileage although it is not a wide band if it reads excessive flow it will dump fuel to compensate.
ive been haveing the same problem. the CEL comes on sooner and sooner everytime. .before it came on every 1000 miles or so with just 1 antifouler..so i put 2 antifoulers on and it comes on within 20 -50 miles..and i noticed when i changed from 91 octane to 89 it started showing up sooner..and my milage went from 32 to about 25 or worse..ive had my car scaned 2 times at autozone for free, and both time i got the same code p1036 bank 1 sensor 2. did you drill your antifouler out to 1/2 inch? i have the drilled out one screwed into the regular one and it still dont work. and the added length of 2 antifouler makes the o2 sensor hit and rattle on something under the car when i put it in reverse which i think might of damaged it. but i think im going to buy a new o2 sensor when the spipe gets here and try over again
