My oil pressure need feedback
I am using a Glo Shift sandwich adapter with a electric Glo shift oil pressure gauge.
When I put this in I was stuned to see the pressure readings
oil is a 5-30 Amsoil full synthetic on a S/C motor
At cold start up oil pressure goes very high 70psi at idle
After getting the engine to running temp
Idle 7-10 psi ( which I know they run a low oil pressure at idle)
3000 RPM 60 - 70 psi
Red line 90 plus
does these readings continue to climb like that because of the sandwich adapter being before the bypass?
Just seems high Have searched the forum and have seen other posts but I know the setup changes it. anyone have any readings to compare.
Second question does the valve lash on the 2.4 need adjusted periodicly?
Red line 90 plus
Originally Posted by highvoltage1
Well why on earth would you go with glo-shift? thats your number one problem. Go prosport or go home.
If I was really going to put a good set of gauges in there they would be Autometer
Im telling you if you want good gauges at a great price check out prosport. Gloshift cant even spell things right on there site and there products are cheap for a reason. But GL.
I was driving today and I noticed that my oil presssure seems like it has decreased recently.
At start up I was around 65-80 based on RPM, but once it warmed up I was some where around 50-60 at cruising speed (around 4000 RPM).
Based on the above, this seems pretty low. Is it a problem?
my06tc
06-25-2015 12:18 AM
jctc06
04-16-2015 12:11 AM
