N/A Cam work?!
Anything about power is speculation at this point. With less advanced cars there's a pretty good way of estimating gains by comparing lift and overlap ratios but we'd be dealing with VVT-i. The ECU has set parameters that it likes to operate within and it'll change the timing until it sees what it likes. That is to say, there's a good chance that simplying changing your cams will result in a net of zero change.
You know, since everyones speculating.
If you get NA cames, I'm sure the community at large will appreciate what you find out. I can't think of anyone who has ever posted about actually going through with NA cams for the tC.
Originally Posted by ToyoCel
06 07 dont even have that much of a power difference. its not enough of a gain to justify spending 500 - 1000 dollars on new cams and install. This is what i want to know. has anyone had their cams done by webcam on an n/a setup.... if so what kinds of gains did you get.
