NA tC with ITB, is it possible??
Old 05-26-2006, 01:43 PM
trdtcpr's Avatar
Default NA tC with ITB, is it possible??
Not long ago I saw the motor FX xA with individual throttle body and I was wondering if this was possible for a tC and what may the performance improvement be? Since it's custom I assume it would not be cheap so more or less how much would this run for? May this cause any problems for the engine?
trdtcpr is offline
Old 05-26-2006, 05:36 PM
dex
dex's Avatar
Default Re: NA tC with ITB, is it possible??
yes its possible...anything is really possible with enough cash. but sinse the tC has the 'drive by wire' computer controlled TB, you would prolly have to convert it to a cable operated system. and this topped with the fabrication of an ITB setup would make it a pretty expensive task. prolly not worth doing on a $20,000 car.
dex is offline
Old 05-26-2006, 07:27 PM
OuterHeaven's Avatar
This would be extremely expensive. Just ignoring the actual fabricating of the ITB's, the ecu would have to be addressed (like dex said) and the tuning would make it expensive. It is extremely hard to tune an ITB setup. Just making the car idle will be an extremely difficult task and would be VERY expensive to tune from scratch. Unless you want you car to become a dedicated race car with all the supporting modifications, then this should probably not even be considered. It will probably not hurt the engine but like I said it is hard to tune and if this is a daily driver it might make it unbearable to drive unless tuned perfectly and may require constant changes.
OuterHeaven is offline
Old 05-26-2006, 08:17 PM
HKSpeed's Avatar
http://www.todaracing.com/itbfaq.htm
HKSpeed is offline
Old 05-26-2006, 08:26 PM
trdtcpr's Avatar
Thanks for the info!!!
trdtcpr is offline
Old 05-27-2006, 07:59 AM
kungpaosamuraiii's Avatar
Make sure you get a hood that'll vent the header's heat!
kungpaosamuraiii is offline
Old 12-09-2006, 05:03 AM
soros151's Avatar
No company willing to make some ITBs? If they do it for RSXs, then why not ours? J/K Just curious as to why Motor FX never finished the ones for the tC.
soros151 is offline
Old 12-11-2006, 03:26 PM
bbsciontc's Avatar
we have a MAF. The honda's have a MAP (Manifold Air Pressure) sensor. In our case, there is no way the ECU is going to know how much air is coming into the engine. If you were standalone you could, but it's not worth the expense for an N/A tC.
bbsciontc is offline
Old 12-11-2006, 03:33 PM
HKSpeed's Avatar
people put ITB's in 4AGE powered AE86 corollas. these motors come with maf sensors too, but are removed. i met a guy who used a piggyback computer to get rid of the maf. i think it was a HKS VPC, but I know Apexi makes a similar product. i wonder if Greddy makes an adapter for the Emanage Ultimate to allow this. either way we'd be looking at $1000-1500 for ITB's + electronics.
HKSpeed is offline
Old 12-11-2006, 03:58 PM
TCpete's Avatar
it is possible to run the MAF on an ITB set up.. please wait until january and you will see it is possible... to give you some thought, if you make a single tube chamber and run the Throttle actuator with butterfly rod and use the other side of the chamber as the MAF location you can do it. just be patient.. it will come out. =]
TCpete is offline
Old 12-11-2006, 08:02 PM
soros151's Avatar
Patience then. :D
soros151 is offline
Old 12-11-2006, 08:31 PM
TCpete's Avatar
Originally Posted by soros151
Patience then. :D
i think you saw my pics lolol...maybe i should post them.. for the non beleivers lol
TCpete is offline
Old 12-11-2006, 09:28 PM
soros151's Avatar
u should
soros151 is offline
Old 12-11-2006, 09:33 PM
tC9o9's Avatar
i hate when people talk but never post pics.. post them pics up if you have em man
tC9o9 is offline
Old 12-15-2006, 05:56 PM
bbsciontc's Avatar
I totally forgot about that VPC. My friend had it in his eclipse which had an atmospheric bov. Didn't hks stop making these though?
Old 12-18-2006, 11:40 AM
toyota_scion_tc's Avatar
You will gain hp by doing this but you will also be sacraficing torque. Everyone I have ever seen do this and dyno you gain a considerable amount of hp but lose tq.
toyota_scion_tc is offline
Old 12-18-2006, 01:48 PM
trdtcpr's Avatar
Patience then. :D
link or pics
trdtcpr is offline
Old 12-18-2006, 05:10 PM
soros151's Avatar
There's photos somewhere around, I just don't remember where TCpete put them. :D
soros151 is offline
Old 12-18-2006, 10:13 PM
TCpete's Avatar
TCpete is offline
Old 12-18-2006, 10:27 PM
soros151's Avatar
how much were them?
soros151 is offline
Quick Reply: NA tC with ITB, is it possible??
