need another clutch!
I installed a new ACT clutch stage 2 on my n/a 2007 about 4 months ago.. and recently it started failing. Car wouldn't go into any gear and my mechanic took apart the transmission to find out that the pressure plate wasnt disengaging and the clutch is almost gone.. probably due to me forcing the gear in to get home. So I plan to get the most stock/oem feel clutch for my car. Should i get an aftermarket like exedy, clutchmasters, act, etc.. or should I just go to the dealer and buy one. Trying to save some money though.
was the clutch orginally installed right,was it aligned and properly torqued,cause the car not going into gear isnt the clutch,it would be the push rod not engaging fully, or purhaps the slave cylinder,cause i know when i had my act installed i had to ajust the clutch pedal which ajusted the push rod...cause i couldnt get into gear...
i wouldnt buy the clutch at the dealer they will charge you a arm and a leg,search online for a 2007 scion tc clutch or aftermarket,buying online is alot more cheaper,i wouldnt even have them install it,ask ur mechanic to do it..
