Need help car idiling rough!!
Need help please!!!
I just chcecked my spark plugs because my car has 85k on it. I pull one out it was in OK condition i put the plug back in and I go to start my car it starts but then its idles at 500rpm or lower. I go drive it try ti floor it and it just bogs down. any ideas?!?!? oh yea and its a 06 tc
I went to go check my spark plugs because my car has 85k. The plug was in OK condition still can be used. I put it back in i go to start my car and it idles rough at 500rpm or lower. I go to drive and i floor it and it bogs down it almost wants to shut off after I floor it. Idk what to do i did everything right. ANy suggestions???
Get your CEL checked
Clean your MAF sensor * go to store get MAF sensor cleaner
Do you have Cold Air Intake? is your intake's small tube is closed and the engine have a small breather on the side? If yes then throw all that out and connect them back together with a hose
Do a Seafoam treatment
i did all these and my idle got much better!
especially when the AC is on... oh god my car use to shake like crazy on idle
OK. I scanned the check engine light. It gave me 10 different codes. MAF and VAF, It said that all the coils are malfunctioned. I clicked the erase option and it deleted all the codes but the MAF. The coil codes never came back. I went and bought MAF cleaner and its still doing the same thing. Any other tips or suggestions????
I'm having the same problem!
I posted it on clubsciontc and couple of those guys are saying its my Torque Converter.
Has it stalled before? Mine did about 7 times within the past few months. Once the car is driven least 20 minutes; the idling is gone and is running like a champ!
cid_mcdp
01-05-2015 03:45 PM
06ScionTc5sp1
18
12-21-2014 08:21 AM
