need help..my car wont shift out of park!
ok, well i get home and turned my car off to go open the gate to let myself in. get back in the car, start it up, and try to shift out of park but it wouldnt let me. yes i pressed the brakess all the way, handbrake was down, all conditions were normal. this has happened before but my friend got it workin again somehow..he said he just tried it normally and it worked..luckily im at home right now and i got my car into the premises by using the little button that lets you shift to neutral when the car is off. i started it on neutral and drove in. put it back into park and tried shifting from it but same problem. any body got any pointers? im sure this is some kind of security locking feature. my tranny runs absolutely fine and im 95% sure its not a serious problem.
sIcKsCiOnS
DelMarVa
Scion Tuners
they are all correct
toyota will not let the car go into gear (automatic) if brakes do not work (lights)
are all the lights out???
try to remove one bulb at a time i had a buld in my probe blow and just the way it broke it was touching somthing and every time i owuld press the break every light in the car and i mean every light excep the head lights would light up the dash the parking lights i had to check every buld and as usal it was the last one that was the culprit after removing it i had no problems
unless you modded your shifter or your electrical system related to it they cannot say anything.
When my car did this i took it to the dealer and they did not say anything about my mods, they figured out the problem and fixed it while i waited.
well the only thing i did was swap a bulb out of the shifter..and even then i doubt they would notice it. my bro helped me with it this afternoon although he is unsure what really happened. he just wiggled the brake switch behind the knee airbag and everything started working again. imma still try to find some time to bring it into the dealership to have it checked out. thanks for all the help guys!
Did you switch out the bulbs in your brake lights to LEDs? If you did, one of the LEDs could have blown and caused your tC to be stuck in park. It happend to a 'friend' of mine. No! this 'friend' is not me!
I had the same thing happen recently, its an electrical problem. After installing the new tail lights on my car, it went into "shift-lock". Unfortunately the manual doesnt tell you how to change it back except to use the little button under the thing you pop off.
Just wiggle the brake switch and you'll be good to go.
