new greddy air diversion panels?
Has anyone tried out the new air diversion pedals? They're only 64 bucks and are supposed to improve cooling thought it might be worth it... http://www.hopupracing.com/grairdipasct.html
to an extent yes. as long as it doesn't interfere with combustion.
if you want to cool the car off more, use water wetter, get some spal fans for the front of your radiator (pull fans), and use header wrap for all the hot parts under your hood.
i don't see how these things would help that much.
guys.. here is the thing.. it does not matter how much air you put thru the radiator... (unless you were having problems with airflow thru the radiator)... you have a thermistat.. and guess what.. that is going to keep the engine at what ever temp it is set to... so unless you change the stat... your only buying bling...
Irishguy0224
03-20-2015 11:21 PM
