Nitrous
Nitrous
i'm trying to figure out where i can tap into my fuel line for the wet shot part of the nitrous system, i'm wondering if i'm gonna have to replace the hard line fuel line for a flex hose type? or is there somewhere i can tap into without removing the hard line.?
Re: Nitrous
Dont worry about it guys , i figured it out. i just replaced the line that goes between the fuel damper and the actual hard line near the firewall... you see the one in between was a plastic hard line with quick releases on both ends and was sheathed in a rubber coating so i just replaced it. thanks for the help tho...one thing which sparks do u recommend that are one step colder than the laser iridium's i got in it now?
I would go one step colder NGK plugs. Dont get platinum! If I were you, I would just go with the regular copper plug. They are cheap to replace if you foul one out. I have better luck with the regular plugs.
I dont have my catalog in front of me but the ones you want should have a "7" in the long NGK number. If you go to a parts store and tell them you want the colder plugs, just make sure when they give them to you, they have the 7 and not a 6. A common mistake with NGK is that the higher the number, the hotter the plug. THIS IS NOT TRUE. The higher the number, the colder the plug. So if he tries to give you a plug with a 6 in it, those are stock. I hope this made sense.
sweet deal thanks, i work at advance auto parts so i should be able to get my hands on some sparks. tho how does ur car run on the copper plugs for normal daily driving? cuz the stock ones are iridiums.
Air Fuel Sensor
White- Sensor ground
Orange- Sensor positive
Yellow- Battery
Green- Heater
hope this helps. i go to school for auto tech so i get alldata which is a program where i can get pretty much anything for any car. so this info is off of the system wiring diagram
Yellow- Battery
Green- Heater
Just fyi - you wont be able to tap into our primary 02 sensor - it uses a current sensing device rather than a change in voltage. Its VERY accurate (similar to any aftermarket wideband) but very unique in the way it works. The guages you buy that tap into the factory 02 sensor are designed to be tapped into a narrowband sensor like our secondary 02 - these have a nominal voltage when running stoich than deviate when running rich or lean but are not very accurate. Hope that helps!
spawnconnery
12-18-2014 09:38 PM
aarontrini85
37
01-24-2009 04:21 AM
