Official Raceland Intake/Exhaust
#41
#46
i jus bout one of thosde...my engine light came on in 3 days but i jus cleaned it n reset the battery so it hasent com back on so far......but if it comes back on im jus gonna return it and get a fujitaa or aem.....jus try it out..u can return it up to 60 days
#48
If your cel came on after time check if you mounted the maf right and its secured to the intake. other than that try resetting your ecu
The breather tube is the small (one inch?) hose that connects to the intake near the TB. The hose doesn't have to be reconnected, I have the G.F.I intake setup and my breather hose is just hanging in the same position as it would if it was connected.(im getting a little breather for it because im lazy to redrill the piping for it) But if this intake comes with a spot for the hose just attach it.
#55
yeah fitments great. it is a little close to the engine cover but isn't touching.
didn't throw a cel yet =]
i would disconnect your battery first. and handle the maf with extreme care if you even dinged it a little you could have damaged it enough to set a cel.
i'm beyond happy with this for the price it was.
the growl after 3000 rpm's is pretty noticeable as well.
if anything just get a new filter and/or a bypass valve/ filter cover for safe messures =]
