P0335 (CKP Sensor Malfunction)
Ive been doing alot of searching but to no avail.. All i found out was it will throw if there is no signal for 4.7sec during cranking... or no signal for .0016 sec while rpm are 600 or higher
Anyone know any more about this code? It has thrown twice now....both while car was running. Idk if it was rich or lean...didnt look at afr gauge and dont have scantool either.
I thought it was my BOV venting to the atmosphere that was causing the problem but then i threw a CEL. I been watching guages closely and it still does it in deep vac (-20inHg) just not as bad, i think the BOV is just enhancing it by making the afr fatten out way rich... Could that be true??
Here is what its doing:
When coming to a stop, the rpm will fall to idle and then start to drop under 500 and rise back up to idle eventually leveling back out stoich. Sometimes it will stall out like if the BOV vents heavily, but its very rare.
Since our cars dont have a distributor... wouldnt the CKP sensor tell the ECM how much fuel and timing, Correct?? Thus causing my stumbling and weird bouncy afr?? Malfunction mean out? or just glitched? or some **** idk....
Would just like some opinions before i drop 120 on a new CKP sensor for no reason.
Thanks in advance.
Thanks in advance.
It's from the F/IC resistor fix. Or lack of I should say.
https://www.scionlife.com/forums/viewtopic.php?t=248460
Wow so i have to mod my boomslang harness?? That would have been handy to know before i put it in the car...looks like im off to radio shack
Thanks Carbon!
It's better to do it after you get the code. Some people (including myself) haven't run into the issue, so it would be a waste to do it before. Just follow the DIY, clear the code and hope it doesn't come back lol.
First off, i know this thread is old but i didnt want to post a new thread, maybe somone can answer this for me. My a/fr has been haywire under normal driving load, and ive been throwing the p0335 code. My boomslang harness came with the resistor mod done, is it bossible the resistor has gone bad and is causing this issue, any help would be HUGE!!!!!
It is extremely unlikely that the Boomslang installed resistors have failed causing an issue that AEM tech support swears doesn't exist in the first place. If your only code is p0335, you can try a new crank sensor or use an oscilloscope to trouble shoot that circuit (I did and discovered that the real problem is the FIC). Haywire AFRs suggest problems with the AFR sensor so look for any associated codes. If you're seeing a P0101 suspect your MAS. If you need a new MAS, the ND part is much cheaper than the Toyota part. Same goes for the AFR sensor. Just cross-reference the Toyota part # to Denso and save 50% or more. Good luck.
well how about that, i am throwing an 02 sensor stuck in rich and also a maf code...i guess ill just have to save the money up and drive it like a granny like i have been!!. so much sh*t to fix, 2 broken jet ski's, sheared my throw out bearing for the second time in a year, shop said clutch looks brand new, just sheared the bearing....time to save to spend!!!!!
Good luck Bro. The better the toys the bigger the cost.
gqdabien
09-17-2015 10:23 PM
