Parking brake light is stuck on
My parking brake light is always on. It use to stay on until I gave it some gas then it would go off. Now it just stays on all the time. Does anyone have any suggestions?
Dont add more fluid unless you find a leak and fix it. If there is no leak and it is low, you need to replace the pads. The fluid level will then be back at the correct place.
And for reference, that is not a parking brake light. It comes on when the park brake is on, but it also tells you when you are losing brake fluid or if there is another brake pressure related issue in the system.
Yes, that is exactly what it is. The acceleration (and inertia) cause the fluid to swish around so it reads low at those times and kicks the light on.
Yep. Checked the pads, and I have a little less than a 1/4 in of pad left. So I topped off the fluid, and hasn't come on since. It's still probably a good idea to change my pads, my local parts store only had the cheap ones, so gunna place an order in a week or so for some good pads.
Thanks
Thanks
Thanks
Thanks
*** Edit, that wasnt aimed at you js. The post it was aimed at has been deleted now so it just looks that way****
^^ didnt you get post removed trying to sell something pretty much right when you joined? As an FYI, posing a ton of few word posts a day just to reach 50 can also get you banned. Mods are not too friendly about that. I say this because bascially every post you have made since then is just agreeing with what others have already said and almost all of them just have a few words in them.
xBSciontist
06-18-2019 03:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
randode
44
06-29-2004 04:19 PM
crystaljukebox_com
12-16-2003 08:34 PM
