Please Help..Socket Size?
I can't find where to get a axle nut socket for my tC.
I can't find the size or where to get one the biggest Snap On makes is 30mm but the post on how to install a flywheel says its 32mm.
Please respond if you know for sure of the size or if you have any idea where to get one.
Thanks
Thanks
Hey, take a look at your keyboard. Above the left-hand shift button, to the left of the "A" button, and below Tab, there is a button called "Caps Lock." See it? Press it to turn caps on/off. Press it now to turn it off, because in forums, TYPING IN ALL CAPS MEANS YOUR YELLING. Thank you.
snap-on sells up to a 38mm socket, even bigger in standered.
and I don't know if it's a 32mm or a 36mm. do you have a snap-on dealer or where are you trying to get your socket from.
check with your local autoparts store, they probably have one you can rent. if not try napa they can order you one, however it won't last long. I've broken three of them with my impact.
rain7905643
03-14-2015 12:48 AM
ColonelSanders85
03-03-2015 03:31 AM
